I have an NOS turn signal switch, C3TZ-13341-B. Can someone give me the layout of the connections? Some colors don't match up with manual.
THX
(1965 F250 2WD)
Turn Signal Switch: 1965/66 F100/250 / 1967/69 F100/350
Can someone give me the layout of the connections? Some colors don't match up with manual. (1965 F250 2WD)
The wires don't match because you have the wrong switch.
C3TZ13341B fits: 1963/1964 F100/250 2WD
C9TZ13341C .. Turn Signal Switch / Obsolete as of a month ago.
Fits: 1965/66 F100/250 2WD / 1966 F100 4WD / 1967/68 F100/350 / 1969 F100/350 before serial number G30,001.
MILLER OBSOLETE PARTS in Binghamton NY has FIVE: 800-546-7278.
PEROGIE ENTERPRISES in Highstown NJ has ONE: 609-448-1684.
GREEN SALES CO. in Cincinnati OH has THREE: 800-543-4959.
ANTIQUE AUTO SUPPLY in Arlington TX has TWO: 817-275-2381.
DON SANDERSON FORD in Glendale AZ has ONE: 623-842-8762.
Sanderson will be the cheapest, Green the most expensive.
Why don't you have the 1964/72 Ford truck parts catalog?
Available on a CD for 22 bucks from hipoparts.com
Once you have the catalog, you won't buy the wrong parts.
Will the one he has have the same color code as a 73-77 switch? I have a diagram for a 73-77 switch.
Or here, I'll just post it. If it won't work, I'll remove it. This is a diagram I made for wiring a 73-77 switch into my 61. It'll be a bit confusing for what you're doing. Yours will have no flasher switch. But, I think you will at least see which wires need to be connected to make the switch function. On my 61, only 1 of the wires is a different color.
