1949 F-3 engine grounding strap
I have a 1949 F-3 with a 239 and a 4 speed transmission. Where should a ground to the frame be located? Where does it attach to the engine/transmission? There should have been a stock location correct?
I am not sure about your specific application but I ground from engine to cab using a strap from bellhousing on engine/transmission to cab (note strap near rear of engine connected to firewall). A strap is also run from frame to negative side of battery (or positive side if its still stock). Make sure the strap contacts bare metal and not paint.
kindorotten
24
Aug 21, 2016 10:18 AM
Vegas123
Mar 10, 2016 08:20 PM
