Ford 226 Ground strap location cab to Bell housing?
Old 12-25-2015, 09:35 AM
Vegas123
Vegas123 is offline
Vegas123 is starting off with a positive reputation.
Hi Guys,
I know this has been covered before but I cannot locate the thread, spent last 45 minutes looking for it.
Where is the original location for the ground strap located at the back of the engine???? Original location for a 49 Ford with 226 H. How long is this strap??
Thanks in advance!
Old 12-25-2015, 09:48 AM
3twinridges's Avatar
3twinridges
3twinridges is offline
3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all
This strap is an original and is exactly 15" end to end.
Old 12-25-2015, 10:02 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
FortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud of
The attachment point is on the head. My battery posts were reversed making the cable too short.
Old 12-25-2015, 06:27 PM
Vegas123
Vegas123 is offline
Thanks for all the pics.
Is there a ground strap that is located at the back of the engine that goes to the cab or frame?
Old 12-25-2015, 10:30 PM
3twinridges
I haven't seen one on any 226 f1 that I have looked at personally and the 6cyl wiring diagram doesn't show one.
Jonathan
Old 12-25-2015, 10:34 PM
3twinridges
The parts book lists 8rc-303-b engine to ground 8 1/4 long but it's only on the v8's.
Old 12-26-2015, 06:10 AM
Vegas123
Vegas123 is offline
Ok Great!
That answers my question. I always thought that the 226 also came stock with a ground strap at the back of the block.
Thank you!
Old 03-09-2016, 11:13 PM
Brian~50F3's Avatar
Brian~50F3
Brian~50F3 is offline
Brian~50F3 is starting off with a positive reputation.
Hey guys my ground strap is 15 1/2 inches long, but won't reach the back of the block, am I missing something? When removed a few years ago it was attached at the coil bracket which I understand is incorrect...?!?
Old 03-10-2016, 03:49 AM
FortyNiner's Avatar
FortyNiner
As I found, the physical locations for the battery posts has been reversed over time. This puts the postive terminal away from the firewall and too long a reach for the stock cable. The alternatives were to find a battery with the legacy post configuration - I'm sure they could be found - or get a longer cable for the positive terminal to head connection. I opted for the longer cable.
Old 03-10-2016, 07:40 PM
ct50f1's Avatar
ct50f1
ct50f1 is offline
ct50f1 is a splendid one to beholdct50f1 is a splendid one to beholdct50f1 is a splendid one to beholdct50f1 is a splendid one to beholdct50f1 is a splendid one to beholdct50f1 is a splendid one to beholdct50f1 is a splendid one to behold
Originally Posted by Vegas123 View Post
Hi Guys,
Thanks in advance!
there was a discussion last year here:
https://www.ford-trucks.com/forums/1...und-strap.html
Old 03-10-2016, 08:20 PM
Brian~50F3's Avatar
Brian~50F3
Thanks guys!!
JayBourbon
12-29-2017 10:23 AM
cranegrad
09-23-2016 08:19 AM
NS70250
08-16-2016 11:45 AM
willowbilly3
07-27-2016 04:47 PM
animator
04-18-2016 12:48 PM
Quick Reply: Ford 226 Ground strap location cab to Bell housing?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
