Sponsored by: Real Truck
'05-'07 Headlight Conversion Question
Old Jul 7, 2013 | 05:33 PM
Punisher29073's Avatar
Punisher29073
For those of you that have done this, what works best for cutting the header panel? I was going to use a sawzall with a bimetallic blade but am concerned about splintering. Isn't the panel fiberglass? Oh well what worked best for you?
Ryan
Old Jul 7, 2013 | 05:54 PM
Punisher29073
Also, did you use the straight splice pigtails or the ones with the relays?
Ryan
Old Jul 8, 2013 | 09:11 AM
Punisher29073
No love for the conversions?
Ryan
Old Jul 12, 2013 | 10:15 PM
shawry's Avatar
shawry
Ryan,
I used a Dremmel with a small cutting disk to do the cutting. The templates for the cuts are on the site somewhere.
I used the relay wires... much better.
Overall not a particularly difficult job.
Old Jul 12, 2013 | 11:11 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I went with a new 05 header panel. I regret it. It is plastic, not fiberglass and weaker. In fact, it arrived broken. Even when I got it in, the right headlight (which is OEM) doesnt quite fit right. I have read there is a piece I need to trim but I cant find out what.
Point is, I wish I had cut my old one. So stick with that plan.
Old Jul 13, 2013 | 12:04 AM
Yahiko's Avatar
Yahiko
I have not done this because I have an 06.
BUT if you have a choice I recommend the relay option
for the headlights. You will have a brighter light because
you would have the loss from the smaller line and the splices.
Just make sure if you brew your own that you put fuses in the
lines.
Here is a handy PDF. It't the Ford Pigtail catalog with color images of the plugs.
http://www.fordtechservice.dealercon...torcatalog.pdf
I keep a copy of this PFD on my computer. It comes in very handy.
Sean
billy_ray90
16
Feb 18, 2014 04:40 AM
80broncoman
Large Truck
Jan 14, 2011 11:00 PM
lifted04xlt
Aug 6, 2009 08:40 PM
ididntdoit99
1997 - 2003 F150
Jan 4, 2008 09:07 PM
Ken2600
Mar 8, 2003 07:31 PM
