New Truck
Old Jul 7, 2013 | 04:14 PM
Doc150's Avatar
Doc150
New Truck
Yesterday I bought a 1991 F250 with the 5.0 and a 4 speed for 320 dollars. its got crushed velvet seats out of a lincoln and the paints pretty bad, little cancer on the rear fender wells and the front leaves are shot. Where's the best place(cheapest) to get 4 new leaf springs? I can't tell if the truck is lifted at all and I know that affects the size of the springs. Its a lot taller than my friend's 94 chevy 1500 and shes got 35s on it.
Old Jul 7, 2013 | 04:55 PM
zombie_killer's Avatar
zombie_killer
Velvet seats from a Lincoln? Looks like you own the first ever F150 that belonged to a pimp. The hand grenade shifter is a nice touch as well.
Anyways, get under the truck and look for lifting blocks on the axle. Don't put too much stock in the height difference between your F250 and a Chevy. Especially seeing as how yours is a 4X4.
As far as replacing your leaf springs on the cheap goes? Your best bet is trying a salvage yard. I know LMC sells springs but you are looking at probably around $800 for all four.
Maybe try helper springs?
Old Jul 7, 2013 | 05:05 PM
GNR22's Avatar
GNR22
What makes you think the front springs are shot. The front springs are intended to be reverse arch. The truck looks to be stock height for an F250.
Old Jul 7, 2013 | 05:50 PM
zombie_killer
+1 on the front springs, they look flat/upside down compared to rear springs.
Old Jul 7, 2013 | 08:01 PM
Doc150's Avatar
Doc150
Why would they be intended to be in the sagging arch? My buddy's chevy is arched like the rear... also my tires are sitting on the inner sidewall almost which to me means the front leaves need to me re arched or get new ones.
http://www.generalspringkc.com/Leaf_...997_s/1870.htm
According to this they're arched...
Old Jul 7, 2013 | 08:48 PM
blue924.9's Avatar
blue924.9
Cause that's how it is, every leaf spring front suspension I have seen is invertedly arched. You say your buddies Chevy isn't. Well that's a Chevy for you, they prolly did it cause they were too cheap and lazy
Old Jul 7, 2013 | 09:32 PM
Doc150's Avatar
Doc150
but that website that sells new springs that I linked to the diagram shows them arched like the rear...
also I was looking around on google images just now and every pic that shows the front suspension, they're arched.
Old Jul 7, 2013 | 09:45 PM
GNR22's Avatar
GNR22
Front leaves on a 4x4 F250 are negative arch. Front leaves on a 4x4 F350 are positive arch. It's just how it is. Also, are you sure you have a 4 speed and not a 4 speed with OD? Ford stopped putting in 4 speeds after 87.
Old Jul 7, 2013 | 09:53 PM
Doc150's Avatar
Doc150
if there is another gear it won't go in. I don't know much about this truck, first truck witha stick I ever drove.
Old Jul 7, 2013 | 10:08 PM
GNR22's Avatar
GNR22
Is the shifter itself straight, or does it bend a few times before it goes through the floor? I just looked at the picture you have posted, and it sure looks like a 4 speed handle. Somebody must have put that in there after they bought it.
Old Jul 8, 2013 | 01:08 AM
Doc150's Avatar
Doc150
there's one bend in it
Peavey1986
Apr 21, 2015 12:36 AM
cub102
Apr 4, 2015 10:36 AM
hotfalcoon
Sep 23, 2010 06:52 PM
gweeds
Mar 17, 2008 11:39 PM
