Steering column
Old Jul 6, 2013 | 01:00 PM
Thood81's Avatar
Thood81
Steering column
I'm needing to find out if a steering column out of a 97 with an automatic will work in my 96 model that is a 5 speed.
Old Jul 6, 2013 | 05:08 PM
glovemeister's Avatar
glovemeister
They should work, but if you are doing it to remedy a wore out column I'd advise you to bite the bullet and rebuild your own. Any used column is or will be just as wore out. You take it out either way so you may as just ensure that is is 100% new versus a used guess.
Old Jul 7, 2013 | 11:56 AM
Thood81's Avatar
Thood81
Could you recommend a place to get a rebuild kit?
Old Jul 8, 2013 | 09:18 AM
superduty4x4's Avatar
superduty4x4
I would advise completely opposite. You can buy used columns for $25-40 at a yard, or spend $100+ to rebuild one. Been there... done that.
OP, yes you can use an auto column in your stick shift. You'd just have to swap a few parts around to remove the auto trans gear selector and put your manual column parts in its place.
Old Jul 8, 2013 | 02:01 PM
kawamatt2's Avatar
kawamatt2
The OP having a manual transmission truck means that he will not have the shift tube bushings to worry about replacing. Therefore the only other wear items in the column are the shaft bearings.
I would agree with glovemiester and advise to pull and rebuild your current column. You can buy the bearing kit from Ford which has been designed to replace the stock stamped wear prone upper column bearings. In fact, Ford issued a TSB to address this wear, 96-23-1.
The rebuild kit can be had for about $60 and comes with instructions to disassemble and reassemble the column.
Old Jul 8, 2013 | 03:29 PM
Thood81's Avatar
Thood81
Thanks for the advice ill most likely go with the rebuild kit
joekacker
Mar 24, 2014 03:00 PM
jakemb
16
Mar 4, 2011 02:36 PM
F-250 restorer
Nov 19, 2009 09:47 AM
Ferngon
May 18, 2007 09:29 PM
77_F150_4x4
Apr 12, 2000 05:42 PM
