Time to replace the carb?
Old Jul 7, 2013 | 10:06 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
They are likely talking about Methanol based drag racing fuel.
Methanol is VERY corrosive to the zinc in brass, and alcohol carbs use stainless steel components with a pure aluminum body.(not pot metal)
Gasoline is petroleum based, with 10% Ethanol added...(for now)
Ethanol plays much better with brass.
Old Jul 7, 2013 | 10:12 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Back when we were racing motorcycles ELF had a racing fuel that would eat right through an aluminum tank or float bowl overnight.
Right after a race, the first thing we had to do was drain everything and flush it out to stop the corrosion.
That stuff smelled very strange in the exhaust too.
LOL, GOOD TIMES! (sorry for the hijack )
Old Jul 8, 2013 | 09:26 AM
JGreen236's Avatar
JGreen236
Definitely not hijacking ArdWrknTrk, i'm loving all the information everyone has provided. Just an update, I was able to buy a new diaphragm and longer screws from my local autozone. Now i'm just waiting on having free time to work on it again. Job, yard work, and babysitting always getting in the way of fun.
Old Jul 8, 2013 | 09:47 AM
Gary Lewis's Avatar
Gary Lewis
You should check the length of the screws vs the depth of the threads. I would run the screws in lightly until they bottom and use calipers to measure the thicknesses of the cover, inc the raised rib, and the diaphragm. Then do the math to see if you have to shorten the screws. And, as someone said, the crimping tools usually have the ability to cut screws while preserving the threads. But, you should allow for some compression in you math.
Old Jul 8, 2013 | 09:51 AM
JGreen236's Avatar
JGreen236
Will do. I was aiming for a helicoil... but autozone, oreilys, and discount didn't carry any that small. If I had more time over the weekend I would have hit up a hardware store. So i'll try with a longer screw and shorten it from there first.
Old Jul 8, 2013 | 09:54 AM
Gary Lewis's Avatar
Gary Lewis
You can take up a bit of extra length with lock washers, which are good to have on that cover as I've had them loosen on me. And it is a pain to have to pull the bowl to tighten them.
Old Jul 29, 2013 | 09:15 AM
JGreen236's Avatar
JGreen236
Hey guys wanted to update everyone after working on the truck this weekend. The carb is now fixed! I installed the new diaphragm and went with the longer screw route. They grabbed onto the hole's threads perfectly. Drove the truck all weekend and not a single fuel leak. With that out of the way I discovered alot of leaking vacuum lines.
Old Jul 29, 2013 | 09:28 AM
Gary Lewis's Avatar
Gary Lewis
Good! But, you are doing as many of us have done - peeling the onion. One problem out of the way exposes a few more. But, there is an end to it all, and along the way you can have onion rings!
Old Jul 29, 2013 | 09:49 AM
JGreen236's Avatar
JGreen236
I'm thinking I may need to replace the brake booster now. Looks like something was leaking at some point where the reservoir connects to the booster. I'm also getting a weird idle once I push in the brakes. Would a failing brake booster cause high idle by any chance?
Old Jul 29, 2013 | 10:54 AM
Gary Lewis's Avatar
Gary Lewis
A bad master cylinder will leak into the brake booster. A bad brake booster will leak vacuum at times and change the idle. Sounds like you need to replace both.
Old Jul 29, 2013 | 06:16 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If brake fluid gets past the seal at the back it will eat the booster diaphragm pretty quickly.
kishkumen
May 25, 2014 06:54 AM
1959_f100
Jan 25, 2009 02:20 PM
JCastellaw
1966 - 1977 Early Broncos
Jun 18, 2008 11:20 AM
elstx
Jan 17, 2004 01:55 AM
