Odd Starting Issue - Need Help!
Old Jul 5, 2013 | 02:41 AM
teddym90's Avatar
teddym90
This is my first post after reading quite a lot so bear with me…
Vehicle: 2001 Expedition EB 5.4 115K auto trans
Issue: Truck will not start when I turn the key, just hear a loud clicking (updated below - new behavior).
Symptoms/Events in order of occurrence:
+ Created spark at wire harness going to Starter Relay on firewall (see “history” below for more) while it was not on the Relay.
+ Later reassembled the wiring and started the truck to hear a loud “ZAP” 4-5 seconds after it started.
+ Found I could not restart the truck & started troubleshooting/testing; the Fusible Link, Starter Relay & Starter all were in need of replacement.
+ Upon replacing these, the truck started. However, after running for about 10 seconds the starter burned out. Now the engine is loud and my hearing isn't great so I can’t 100% say whether the starter kept running or it reengaged. I was advised by a cousin that owns a shop that the re-manufactured starters tend to be problematic so I went and bought a new one.
After replacing the starter a second time I started the truck and shut it off in quick succession 2x. However, on the 3rd attempt I found the truck would not start again. I was able to jump the Starter Relay by running a wire from the lower post to the Positive terminal on the battery; I should note that when it starts it is a slow wind up and not an instant crank (only for 1-2 seconds but noticeable).
This lead me to the Ignition Switch, which tested fine but I replaced just to be sure. After reassembly the truck started up fine, and I repeated my test of shutting it off quickly. This time on the 3rd attempt I left it running and did not hear the starter running/reengaging after a few seconds. Unfortunately, after 30 seconds I stepped back thinking all was well and 5 seconds later the starter burned up again.
I had read that the less expensive starter relay I had bought can stick and burn out starters so I replaced it, only to find that after 3 quick starts now the starter is not engaged and I can only get it to start by jumping the Relay again. Not wanting to waste any more time or money (it’s been nearly 2 weeks) I thought I would post here for advice on next steps.
I believe my next area of interest is back to the ignition wiring or TRS (T-ransmission R-ange S-ensor). However, having spend the last 2 weeks reading, troubleshooting and being frustrated I feel like there may be something I’m missing. I see some sort of Anti-Theft Ignition Interrupt Relay on my wiring diagram but I cannot for the life of me find it or any information in my manual or on the internet that would lead me to it.
Thanks in advance for your advice folks!
Little more history for those interested:
The Self-inflicted injury came while in process of recharging the AC. You might ask, why the heck would you be messing with this stuff just to recharge the AC… well for those that haven’t had the pleasure, the lower AC port is on the Accumulator, which happens to be back by the firewall under a bracket, who’s bolts are under the cables for the Starter Relay. Anyway, I accidentally brushed the wire harness that goes on the starter relay against the firewall... I had pulled the negative battery cable off and away but it snuck back up and was touching the post... it's never happened to me in my 20+ years of working on cars/trucks but talk about an instant heart sinking feeling
Long story short, when I started my truck to continue with the AC recharge, the loud zap came after about 10 seconds, which was apparently the sound of the fusible link and half my starting circuit burning up.
Old Jul 5, 2013 | 06:35 PM
teddym90's Avatar
teddym90
Little more testing and a new symptom
Tested for power at the TRS wire harness (poles 9 & 10) and found that they were each appropriately powered with the ignition at Run & Start accordingly (9=Run / 10=Start).
After deciding I wasn't terribly comfortable removing the TRS (there is almost no room to reach in and disconnect the shift control cable) I reconnected everything and tried to crank it over, which is where my new symptom appeared.
Initially, the original click followed by no start occurred but I realized I could hear an electrical humming from under the dash area. I moved to laying on the floor with my head under the dash and tried to crank it over again but still couldn't pin point it. However, on the third try my Starter briefly engaged. On the 4th try my truck started.
I was a little shocked and to avoid burning up the starter I shut it off right away. To restart it took the same number of tries; three turns with just electrical humming, one with a brief buzz of the starter and finally the truck started. On the third round of this the starter went into hyper drive, or at least that's what it seemed like to me, as the engine started and was revved up super fast for a few seconds before I cut it off.
I'm feeling a bit out of my league but thought I would check once again for any input this group might have.
Thanks!!
Old Jul 5, 2013 | 11:02 PM
alloro's Avatar
alloro
Any chance there is a remote start unit wired into the system somewhere?
Old Jul 6, 2013 | 01:49 PM
teddym90's Avatar
teddym90
Nope
There is not a remote start but thanks for the idea!
nickniles
Modular V8 (4.6L, 5.4L)
Jul 21, 2018 05:39 AM
taylerallen6
1997 - 2003 F150
Jun 21, 2016 06:45 PM
ktbrach7
Dec 10, 2012 05:24 PM
BigJim191
Mar 25, 2007 06:18 AM
kjsharrer
3.8 & 4.2L V6
Apr 26, 2002 07:02 AM
