Another disc brake conversion question
Old Jul 4, 2013 | 02:59 PM
march's Avatar
march
I'm in process of converting rear brakes on my F250 to disc. Using 75 K20 parts. Got it all together, but there is no clearence between the rotor and pads. I can move the rotor by hand, but there is significant drag. The pads do have shims, but I thought those were for noise more than spacing. Can I remove them?
I also want to confirm that the spring clips are for the inner pad to keep it positioned in the piston. I'm guessing since I have no reference.
Old Jul 4, 2013 | 07:30 PM
liquor crazy's Avatar
liquor crazy
are the rotors new you are using? I had significant drag on mine had them turned . they ended up being warped. no more drag and spring clips I cant remember but probably
Old Jul 4, 2013 | 07:46 PM
ranger429's Avatar
ranger429
Yeah if your using new rotors you should have them machined. You can remove the shims to gain clearance and if it squeals they make a liquid disc brake quiet you can apply to the back of the pad.
The spring clip should go into the caliper piston to hold the pad in place.
blairsie
Apr 3, 2017 07:23 AM
texastech_diesel
Apr 17, 2011 09:47 AM
66f-100
Apr 19, 2010 05:24 PM
LT/PM
1997 - 2003 F150
Apr 15, 2010 05:14 PM
boulderdentist
Mar 17, 2006 10:17 AM
