simple body lift question
Old Jul 4, 2013 | 03:46 AM
rustytrusty26's Avatar
rustytrusty26
Im putting a 3 inch body lift on my truck as well as a 4 inch suspension lift. Ive made all the brackets and blocks for my body lift. My only question is will i have to extend my stering stem?
Thanks for the help corey
Old Jul 4, 2013 | 04:14 AM
rustytrusty26
Forgot to ad my truck is a 1995 f150.
Thanks corey
Old Jul 4, 2013 | 09:15 PM
zombie_killer's Avatar
zombie_killer
when I installed my body lift, I took the precaution of disconnecting the steering shaft, but was able to reconnect it with no hassle. I will tell you when you install your 4" suspension lift, you will have to have your drive shaft lengthened. At 4" your rear will barely be on the tail shaft.
Old Jul 4, 2013 | 09:22 PM
GNR22's Avatar
GNR22
Your driveshaft should be fine. They're usually still good up to 6" of suspension lift. You shouldn't need a steering shaft extension with only a 3" body lift.
thezhlane
15
Dec 30, 2015 04:54 PM
statley chubs
1983 - 2012 Ranger & B-Series
Nov 9, 2009 09:45 PM
83Ford2x4
May 3, 2007 09:38 PM
Mychal
Feb 12, 2004 09:05 PM
truckman79
Jan 21, 2003 05:12 PM
