Getting my truck to (what Rich says)
So the 100% thing has been thrown around here a lot recently. I'm wondering where a good place to start is. I am seriously considering sticks, turbo, AIS, possible HPOP, and changing tuners. Do y'all think I should pull my current tuner before I jump in or leave it? I'd like to put together a comprehensive list of things to test/check (in logical order) before lighting my debit card up. Any suggestions are appreciated.
this 100% thing really isnt that hard....make sure you dont have any boost leaks....if you do put is some nice uppies and be done with that....turbo boots....the stock ones suck....get some nice aftermarket boots.....make sure you tighten your wastegate down as much as possible so you dont release air to soon....get all the air out of the fuel.....i am a huge advocate for a regulated return-tank mods-an air dog lift pump and or maybe a sump.....get all the air out of the fuel and you notice a smoother running truck....you dont need injectors unless yours are worn or if you just want to upgrade....hpop....buy an aftermarket one and stick in a new ipr and icp all at the same time......oil-fuel-air....its that simple really....
i just noticed you already have bellowed uppies....
what is it you are worried about and/or trying to accomplish?
Not unhappy with my current tunes at all. It is entirely my fault for slapping a tuner on when I first got the truck without fixing everything else first. I think I may be convinced to stick with DP, I'll just HAVE to upgrade to the F6. Pulling this chip for reburn would be a PITA I'd rather avoid.
I have to find my stinkin' OBDII USB thingy first! I should ask you how you like the HD4R100/BTS VB/DP Tunes combo. I have been considering the BTS VB, but had some nasty shifts with my old trans (4R100 no mods) with this tuner. I would say it was the trans trying to tell me something but I got 130K out of it after the tuner. I'm not a fan of the shifting with my new trans, but it doesn't break my neck in the 2-3 shift like it used to.
What tunes do you have now? What don't you like about them? Also what are all of your mods? (I apologize if they are in your signature. FTE Mobile does not display signatures.)
Here is a video I made on making a boost leak detector. Once that is done I recommend watching another one of my videos about fixing boost leaks. Boots are a big part but I would recommend plenum inserts (at a minimum) or replacement plenums.
I'd like a solid running truck with a little more power than I have now. I had plans for boots but didn't even think about fuel. I figure it's time for sticks with 230K on the clock so why not upgrade a bit. I just replaced IPR and ICP a year ago. Do you think they're still needed?
with one of these if youre not very handy yourself....if you still have the stock turbo youll need the 3" version.....
http://www.dieselsite.com/dieselsite...etector-4.aspx
