Sponsored by: Real Truck
Grinding Noise Front Driver's Side When Decelerating
Old Jul 3, 2013 | 10:02 AM
PeteB4's Avatar
PeteB4
Grinding Noise Front Driver's Side When Decelerating... seems to get louder as I coast to a stop. Tire is wearing unevenly...
Any thoughts?
Thanks!
Old Jul 3, 2013 | 10:24 AM
redford's Avatar
redford
FTE Leadership Emeritus
Uneven tire wear is a sign something is not correct, but you need to be a little more descriptive. What part of the tire is wearing unevenly?
Does this grinding noise change when you apply or release the brakes?
Old Jul 3, 2013 | 10:28 AM
PeteB4's Avatar
PeteB4
Thanks RedFord! Inside of tire uneven wear pattern...like every other tread print. Brakes or no breaks it grinds. I notice it when I slow down (less engine noise maybe). Kind of rhythmic, rolling, grinding...
Old Jul 3, 2013 | 10:29 AM
r2millers's Avatar
r2millers
Any thoughts?
Thanks!
If 4x4, sounds like a front wheel bearing going bad. You must purchase a new sealed unit to replace if the cause.
Other obvious issue is the brake pads worn out, metal to metal contact, but wouldn't expect to hear iT when decelerating.
With tires wearing poorly, check your upper and lower ball joints too.
Old Jul 3, 2013 | 10:36 AM
PeteB4's Avatar
PeteB4
Thanks r2millers! Ball joints were just checked. How $ for bearing replacement??
Thanks!
Old Jul 3, 2013 | 10:51 AM
r2millers's Avatar
r2millers
Thanks!
On Amazon...
515020 New Front Wheel Bearing Hub Assembly Fits Ford Excursion, F250, F350, F450, F550 4x4 : Amazon.com : Automotive 515020 New Front Wheel Bearing Hub Assembly Fits Ford Excursion, F250, F350, F450, F550 4x4 : Amazon.com : Automotive
Old Jul 3, 2013 | 11:00 AM
PeteB4's Avatar
PeteB4
thank you r2millers
Old Jul 3, 2013 | 11:01 AM
redford's Avatar
redford
Check the front axle U-joints also, although you'll usually get a lot more than a grinding noise if those are going bad.
Old Jul 3, 2013 | 11:03 AM
PeteB4's Avatar
PeteB4
redford, what will those sound like??
Old Jul 3, 2013 | 11:04 AM
senix's Avatar
senix
This does should like a hub replacement time.
Old Jul 3, 2013 | 11:11 AM
PeteB4's Avatar
PeteB4
senix, the one from amazon above look good??
Old Jul 3, 2013 | 11:30 AM
Firekite's Avatar
Firekite
You have yet to say what truck you have. It makes it really difficult to give you advice--much less part numbers--with no information.
Please list at least the year, model, trim level, whether it's 4x4, and whether you have auto- or manual-locking hubs.
Old Jul 3, 2013 | 11:36 AM
PeteB4's Avatar
PeteB4
2000 F350 XLT with the V10. 4X4 with manual hubs.
Old Jul 3, 2013 | 12:09 PM
senix's Avatar
senix
It appears that one is good for your year. Yes, replace both!
Old Jul 3, 2013 | 12:12 PM
PeteB4's Avatar
PeteB4
That's what I was thinking.
Mattstunt929
Jun 5, 2019 11:17 PM
jim20j
Escape & Escape Hybrid
Jul 17, 2012 03:58 AM
romod
1983 - 2012 Ranger & B-Series
Oct 19, 2010 07:02 PM
lzrj
Sep 30, 2008 03:13 AM
grizzly041771
1997 - 2003 F150
19
Jun 26, 2008 08:48 PM
