Trailer Towing Capacity
Old Jul 2, 2013 | 12:24 PM
awonboys's Avatar
awonboys
what is the towing capacity for my truck. 2007 F-150 4X2, V-8, 4.6L engine Supercab.
Old Jul 2, 2013 | 07:34 PM
CaptFX4's Avatar
CaptFX4
Need to answer 2 more questions, what gears do you have and what is the Wheelbase??
with 3.55's GCWR is 11,500 lb with max 6,600 towing on the 126" wb
11,700 lb with max 6,700 towing on the 144.5" wb
with 3.73's GCWR is 12,000 lb with max 7,100 towing on 126" wb
12,200 lb with max 7,200 towing on 144.5" wb
Hope this helps.
Old Jul 5, 2013 | 05:44 AM
chuckczrxoa's Avatar
chuckczrxoa
Got a stock bumper? The info is stamped on the bumper.
Old Jul 5, 2013 | 09:38 AM
danorules's Avatar
danorules
The info on the bumper is for a bumper pull, if you are using a receiver hitch you will have higher capacity like what captfx4 posted up
Old Dec 27, 2013 | 08:07 PM
bfgoodmudder's Avatar
bfgoodmudder
I have an 04' Fx4 and I'm wanting to pull a car trailer with a 3/4 ton 72' chevy about 280 miles. My door sticker shows a ridiculous 3800lbs or something like that. That worries me a little but the other numbers I see guys throwing around are quite a bit higher. My truck has a receiver hitch and is 4x4 obviously. Anybody know why the door sticker is low?
Old Dec 27, 2013 | 10:32 PM
CaptFX4's Avatar
CaptFX4
Yeah something's off. With the 5.4 max tow is in the 9000 lb range. I tow a 6500lb camper with my 05 5.4 with no issues.
My only guess is that 3800 lbs is how much each of the stock e rated tires hold at max psi.
Old Dec 28, 2013 | 12:39 AM
bfgoodmudder
Lol, I was looking at it wrong. I was looking at the front and rear ratings. It shows a 7200lb rating so hopefully with wife, myself, two daughters, daughters boyfriend, gear, tools, etc... we will be ok. I'm pulling an old steel dual axle car trailer and I have no idea how much it weighs. The truck should be in the 14-15k range total right?
Old Dec 28, 2013 | 07:53 AM
CaptFX4's Avatar
CaptFX4
I'm guessing you have the 3.73 gears but you'll be fine for that length of trip. Don't expect to set speed records but you'll be able to go the speed limit. Turn o/d off and the truck will pull fine.
Expect 8-9 mpg.
Enjoy your trip!
Old Dec 29, 2013 | 05:53 PM
bfgoodmudder
Just made it back. Truck pulled great. Actually got close to 12mpg at about 60mph and a little help from the wind. I'll post a pic of the rig in a bit...
Old Dec 29, 2013 | 09:52 PM
lerayluanhe's Avatar
lerayluanhe
jimmycat
All Things Towing
Oct 9, 2010 07:45 AM
gunit024
13
Jul 24, 2007 11:07 AM
Omied
2004 - 2008 F150
Jul 2, 2007 10:07 AM
lspall
1997 - 2003 F150
Jan 2, 2007 11:21 PM
JustinH
All Things Towing
Jun 11, 2004 09:05 AM
