General Automotive Discussion
DIY: Testing for Continuity with a Multimeter (Vid Tutorial)
Old Jul 2, 2013 | 11:42 AM
ProStreetDriver's Avatar
ProStreetDriver
Video tutorial on how to test an electrical circuit for continuity/break in the wiring or a poor connection.
Procedure:
-a multimeter is required for this test
-using a multimeter, set the multimeter to the lowest ohms increment or to the continuity setting if equipped
-put the test probes together to determine the lowest value the multimeter will show a reading of (if the reading is not 0, this can be caused from a low battery or dirty test probes)
-determining where the wire run, check the continuity/resistance between point A to B by placing the testing probes on the wire contacts
-determine the value given
-if there is an excessive amount of resistance or no continuity within that particular wire you are testing, there could possible be a break in the wire or a loss connection
-inspect the wiring for any corrosion in the contacts
-inspect the wiring for any breaks in the casing
-inspect the wiring for any corrosion leaking out of the casing
-pull along the wire to see if it "stretches" (broken wire within the casing, which is still held together by the exterior casing/insulation)
-using a needle, penetrate the casing and test for continuity/resistance in the plugs or between points A and B
-once the problem is found, take the correct actions to resolve the issue
Causes:
-corroded wiring
-corroded connectors
-break in the wire
-break in the casing which caused the wire to corrode
-break in the casing to cause the circuit to short out
-constant bending or strain on the wire which caused the wire to crack
Possible Repairs:
-if contacts are corroded, clean contacts using a solution or an abrasive pad
-if casing is broken, repair using silicon, shrink tube, or electrical tape
-if wire is broken, a section can be cut out and replaced by soldering or using solderless crimp connectors to attach the new wire
-the entire harness can also be replaced if chosen
bkuuz1
Oct 2, 2014 09:23 AM
nevets350
May 17, 2014 05:47 PM
Tuck1231
Jun 5, 2006 08:17 PM
Greywolf
Garage & Workshop
15
Oct 8, 2004 10:36 AM
doug84xlt
Feb 17, 2004 02:12 PM
