EGR Delete in progress
Old Jul 10, 2013 | 07:16 PM
JaySVX's Avatar
JaySVX
so sinister oil cooler is what i'm after right? or is there a better one?
Old Jul 10, 2013 | 09:57 PM
dlibson's Avatar
dlibson
The Sinister is an OE replacement. That will work fine.
Old Jul 10, 2013 | 10:10 PM
dlibson's Avatar
dlibson
You won't need intake bolts either. But take a look at the coolant flush procedures as well. You need to do some really good flushing of the system.
The other issue is that you have more to do. I would plan on a water pump, t-stat, new hoses, overflow bottle and cap, and flush, flush, flush.
Old Jul 10, 2013 | 10:45 PM
BLADE35's Avatar
BLADE35
Take A Hose and Stuff in that thing
Run it in the thermostat Hole with Block Drains Open Kinda a Reverse Flush of the Block
Stuff it in the Radiator with Hoses Off Let it Run
Stuff that Hose in the Heater Intakke Hose/Valve
Also when your Oil Cooler is Out Stuff the hOSE IN THE hOLES FOR Coolant supply to Oil Cooler Coming from the front cover
Try to Flush as much of that Junk out as you Can Before you start it with the NEW OIL COOLER
A Good Flush you should be OK just check them Hoses regularly they might get soft But sounds like you caught problem Fast
Have you checked the Oil to see How Low or how many qts are in the cooling system
Old Jul 11, 2013 | 04:40 AM
JaySVX's Avatar
JaySVX
My oil is still registering only on the low side on the dipstick, so it couldn't have been more than a quart or two. I went from my house to the church, to my parents, and back to my house, total of two miles round trip. I went back and checked, nothing on the ground at the church. A little on the ground at my folks place, and more at my house when I arrived home.
I put in a new t-stat a few months ago, wish I'd have kept the old one now... I'm going to flush as much as possible. I really hope I don't have to add a water pump to this job...
Old Jul 11, 2013 | 06:22 AM
dlibson's Avatar
dlibson
Flush it good like Benny said. Dump some simple green in it after with water and let it circulate with no t-stat in. Then flush some more. The simple green will help loosen the oil out of the system. You can try to save it all.
If the water pump ends up pushing air after this it will cavitation will eat the front cover up. Then you have bigger problems. So flush, flush, flush...
mcompton1973
Aug 27, 2018 08:13 AM
lkforney11
Sep 1, 2016 12:44 AM
joshofalltrades
Mar 9, 2013 04:08 AM
wgcdc
Nov 23, 2011 07:33 PM
2006powerstroke90
Dec 9, 2010 02:09 PM
