Starting Without Ignition Switch
Old Jul 1, 2013 | 01:57 PM
phil_idi's Avatar
phil_idi
I have been having some ignition switch problems that I think I have fixed on my 1986 F250 6.9 IDI, but I am just wondering what is involved in jumping the starter solenoid manually and where is it located if I can't get the key into the start position, if I need to get out of a pinch?
Thanks for your advise.
Old Jul 1, 2013 | 02:09 PM
ihateminimumwage's Avatar
ihateminimumwage
Jumper wire from the battery positive to the FSS on the injection pump (if your ignition switch won't power it in the 'on' position). You most likely have the regular solenoid on the passenger side fender; You can jump the starter using a screwdriver from the big post on the solenoid that the + battery cable is on (the one that goes to the battery, not to the starter) to the closest small terminal.
It works in a pinch.
Old Jul 1, 2013 | 02:44 PM
tjc transport's Avatar
tjc transport
i ain't rite
and make sure the manual trans in in neutral with park brake set or park if an automatic before doing this, or you will run yourself over.
Old Jul 1, 2013 | 03:04 PM
ihateminimumwage
Yes, definitely make sure it's not in gear!
Old Jul 1, 2013 | 05:14 PM
bashby's Avatar
bashby
Starter relay (solenoid) is on the pass side fender. It has 2 big terminals and 1 small. Pull the wire off of the small one, it is red with a blue stripe. One of the big terminals goes to the battery, jump from that one to the stud on the relay that the red/blue wire was on with a screwdriver, nail, etc.
gcm4255
Jul 25, 2020 01:21 PM
ford4her
May 16, 2015 05:32 PM
judi48
Aug 21, 2014 11:15 PM
wapiti_j
Jul 17, 2008 11:29 PM
podman152
Nov 29, 2004 06:57 AM
