Totally weird fuel pump issue
Old Jun 30, 2013 | 07:00 PM
voodoolord's Avatar
voodoolord
I just replaced the front tank and fuel pump a month ago. The tank was nasty and the pump float was rotted as well as the pump not running. The whole unit worked great for the last month until a couple days ago I started down the road and the truck started stumbling and died. I pulled over and noticed the fuel was low in the filter so I switched it to the rear tank which still works.
I jumped the relay and the rear pump runs but when I switch it to the front pump theres no action from the front pump. Heres the weird thing, with the relay jumped and the rear tank selector and ignition on the rear runs but when I switch to the front with the relay jumped it wont run until the ignition switch is off. Then it runs but no fuel comes out like its running backwards or something. Theres obviously power getting to the pump with the ignition off and the relay jumped.
This is a brand new Carter pump and a new fuel tank so Im kinda stumped. Any ideas out there?
Old Jun 30, 2013 | 07:10 PM
harrelle's Avatar
harrelle
Did you replace the fuel tank switch/ valve? I had a diesel (1984) and it would do nothing but suck air from the return line(bad selector valve). I just hard lined to one tank and it ran great till I got another valve.
Old Jun 30, 2013 | 07:23 PM
voodoolord's Avatar
voodoolord
I didnt replace the switch valve because it seemed to work fine. You can hear the switch actuate when the selector switch is flipped. I dont think the switch keeps the power from the front pump but I may be wrong. The problem is the pump is not running when selected to the front and does on the rear. The sending unit on the front pump is working fine though.
Old Jun 30, 2013 | 07:32 PM
harrelle's Avatar
harrelle
The problem I had was a lot of air in the lines. I would switch back and forth from front to rear and suck air. It left me on the side of the road many times. The switch rotted inside and would draw from the return and supply. Causing air. But in your case I would jump each pump to see if they are working then back track from there. If you only have one pump and it shuts off from tank to tank its a switch or tank valve problem I would guess.
Old Jun 30, 2013 | 07:50 PM
voodoolord's Avatar
voodoolord
Dual tanks with dual pumps. Im in the process of checking for voltage to the front pump. Just need to find which wires out of the 4 are to the pump not the sending unit.
Old Jun 30, 2013 | 08:02 PM
harrelle's Avatar
harrelle
Wish you the best of luck let us know what happens
Old Jul 1, 2013 | 12:23 AM
voodoolord's Avatar
voodoolord
Im getting about 10.30 volts to the fuel pump and Im not sure what that means. Im still not sure which wires on the pump go to the pump its self and which are for the sending unit. Ill have to check it again in the morning.
Old Jul 1, 2013 | 08:24 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Voodoolord, Do a search on here, there have been several postings of the 1985 460 fuel pump wiring. I have the 1986 on my website, but it is different from 85, yours has two relays, 86 only uses one.
Old Jul 1, 2013 | 02:28 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I believe the SPDT *selector relay* default position is 'rear'
If you are powering the front pump directly it is just deadheading into the tank switching module.
Subford has the color coded wiring diagrams for the '85 setup.
Old Jul 1, 2013 | 03:55 PM
85lebaront2
Thanks, Jim, I couldn't remember who had it.
Old Jul 1, 2013 | 08:41 PM
GLR's Avatar
GLR
As mentioned go through the trouble-shooting steps. On the plug-in to pump/sending unit there a 2 grounds. 1 for pump,1 for sending unit. I went through 4 NAPA/Carter rear tank pumps. One didn't last 5 miles. Put in an Airtex working fine after a year.
Old Jul 1, 2013 | 09:36 PM
85lebaront2
One more issue I ran into on all of the aftermarket senders, the sender ground is a dummy. The Ford units had brass washers on the sender ground pin, the aftermarket ones have all four pins insulated.
88 XLT.302
Jan 17, 2015 12:02 PM
foolgator1
Jun 14, 2012 12:38 PM
Grey89F250
Mar 20, 2008 05:56 AM
JimPalaSS
Feb 26, 2006 10:35 PM
93Sunplex
Oct 3, 2005 10:42 PM
