Sponsored by: Real Truck
low beam headlights not working...HELP!!!!
Old Jun 30, 2013 | 03:51 PM
fireengco1's Avatar
fireengco1
Ok . im about ready to pull out my hair......... just bought a 2004 f-250 checked everything out except for the headlights ... when I tried them the didn't work except on flash to pass ... I searched around and found some possible solutions and tried them .... first I checked the bulbs and all the fuss they are good then I bought a headlight switch ....that fixed the problem for about two days then they quit working again... so I took it back and got a new one ... when I first put it the new one in it didn't work then it started working a day or so later and I hadn't done anything to make it work... then a couple days later it went out again ... I have swapped the switch out several times and have had no luck I replaced the multi function switch and still no low beams ... all the fuses are still good I have checked the wiring visually as much as I can see and see nothing... buddy of mine checked the pins on the headlight switch connector they are all good ..read something last night about a guy whos alternator was going bad and caused his not to work checked mine its putting out around 13.4 at idle .. is there a relay somewhere ... my book doesn't show the function of any of the relays so I don't know ...not a mechanic but a pretty decent parts changer .trying to fix this myself just a po fireman would hate to have to pay a shop to fix something that still might be simple but I am at witts end ..suppose to be heading out of town with the family next week have to take the truck to pull the camper ...please help
<!-- / message -->
Old Jul 1, 2013 | 05:29 AM
projectSHO89's Avatar
projectSHO89
Sounds like an intermittent wiring harness on the column.
Does it get worse or better with the tilt column all the way up or down?
Is the truck equipped with DRL?
dalesimp21
2004 - 2008 F150
Sep 29, 2012 07:06 PM
TheRon
Bronco II
Feb 28, 2009 11:43 AM
jjjreynolds
Aerostar
Dec 15, 2007 10:03 AM
brettds
1997 - 2003 F150
Dec 10, 2007 12:40 PM
John_E
Sep 23, 2002 11:31 PM
