'98 Headlights don't work
Old Apr 8, 2002 | 03:29 PM
John_E's Avatar
John_E
I have a '98 Explorer that my headlights stopped working at the same time. The parking lights still work and when I pull back on the dimmer switch I can flash the high beams but they will not stay on.
It did this a few weeks ago and I turned the high beam on then back to low beam and the headlights stayed on, but now there is nothing. I am going to replace the headlight switch today. I don't know if this is it or not. If anyone has experienced the same please let me know whow you fixed it. Thanks.
Old Jun 28, 2002 | 11:23 PM
98_explorer_owner's Avatar
98_explorer_owner
My '98 Explorer headlights did not work once and the park lights did.
It was the hi-lo beam adjustment switch position. I think I may have
bumped into it and knocked it into a position to stop switch contact.
Good luck....
Old Aug 30, 2002 | 07:18 PM
yonkers733's Avatar
yonkers733
Post '98 Headlights don't work
I realize it is an old posting, but I am experiencing the same problem with my '96. I changed the headlight switch and I still had the same problem. How were you able to solve the problem? My guess is that there is a relay somewhere that I am not aware of.
Old Sep 23, 2002 | 05:45 PM
yonkers733's Avatar
yonkers733
Got it! The culprit was the multi-purpose switch on the steering column. Boy - it would have been so much easier if I had known the multi purpose switch could also wipe out the headlights. Replacing the headlights switch was a bear and it proved not to be necessary!
Old Sep 23, 2002 | 11:31 PM
97 awd xlt blue's Avatar
97 awd xlt blue
