About every two years I need to grease my drive shaft's slip joint to "cure" that annoying, subtle, soft "clunk" when driving off.
I keep a three-ounce tube in my center console of Ford's special aquamarine-colored grease. It's called XG-8, and every good Ford parts counter man knows about it
Until recently, when I put the drive shaft boot back on, I secured it with a common plastic tie wrap. It may, or may not, last the two years. So far, I've been lucky.
Nice find POP indeed. Now I just have to pay the 50 bucks to get em here
If you don't like the import prices, you could always just take a piece of thin gauge galvanized wire and use some pliers to twist the wire so it's as tight as this would be.
Might be low tech, but folks have been using that method for years to fix things. I don't know the prices over there, but here you can buy 1/4 mile of 14 ga. galvanized wire (electric fence wire) for around $20. (used baling wire is another good substitute, but it's a much heavier gauge)
I got the steel ones from HF a couple years ago and could not figure out how to make them stay tight, they kept slipping back out on me, and they wouldn't pull up very tight to begin with.
Chunder/Brian
Does it really cost that much to "mail" something down there or or is it a mandatory customs/duty thing that everything goes through regardless of "shipping" method? There was a thread some time ago - not sure if here or another forum - that was building a 7.3 Toyota Landcruiser in S. Africa and could not get some parts into the country no matter what.
I did this at 105k like 6 years ago. Took a flat head screw driver and pried the stock clamp apart just enough to move the boot. Greased it with Lucas red and tacky then reinstalled the same clamp using a set of wire nippers not cutters to squeeze the clamp back together. Works great and able to obtain stock clamp. When I get home I will take a pic of the nippers and show y'all how I did it
Chunder/Brian
Yeh I did read he's thread. was interesting. I might of over exaggerated a little. It would be around the 20 mark.. My experience with little items by mail is they dont turn up.
