Valve spring question
Old Jun 30, 2013 | 11:47 AM
mdlave's Avatar
mdlave
I'm currently rebuilding a 460 from a 1973 Lincoln to go back into a 1978 F150 4x4. C6 transmission, headers, 750 Holley Carb, stock intake.
I want to upgrade the cam as part of the rebuild. How much of additional lift will the stock valve springs handle? Am I asking the right questions?
If it is a good idea to replace them anyway, would new stock springs be okay or should I go with ones included in a cam,lifter, etc. kit?
Old Jun 30, 2013 | 12:08 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Replace the springs. When you buy the cam get the complete cam and kit that the cam manufacturer offers.
These kits are engineered so all the components work together.
The lifters should also come with the kit. Never, ever reuse old lifters on a new cam!
Old Jun 30, 2013 | 08:36 PM
F-250 restorer's Avatar
F-250 restorer
X2 on all that.
Old Jun 30, 2013 | 09:12 PM
mdlave's Avatar
mdlave
Thanks. That settles that.
Any recommendations for cam/lifter/valve spring combos besides the comp cams packages? Or are they the best bet?
Old Jul 1, 2013 | 09:29 AM
mikeo0o0o0's Avatar
mikeo0o0o0
It really depends on what you want to do with the truck.
I like Competition Cams but there are several others out there that offer equivalent grinds.
If you're building a daily driver then I would go with a mild hydraulic grind, short duration and overlap, higher lift, smooth idle. That's where you'll get more bottom end torque.
If it's more a weekend cruiser then you could go wilder with more duration and overlap, that's where the "lumpy idle" comes in but you'll lose bottom end torque and get top end horsepower.
A lot of manufactures websites have "cam finders". Answer the questions and they recommend a cam grind.
Old Jul 1, 2013 | 07:57 PM
KIKKUP's Avatar
KIKKUP
One thing I'll add is since the rest of your motor seems stock is to stay more on the mild, lower rpm side. There are some good grinds out there that will not penalize your vacuum and that's what you want when you have an automatic. I will recommend that when you do this you consider replacing your stock type umbrella valve stem seals with some Viton units. Stay away from the Teflon. (I bought those and busted two of them installing, they are way too hard). Not sure if all of Viton types require machine work but mine did and it was easily done with a hand drill and the proper tools comp cams sell. The cam I picked was a Lunati 10340702, 1400-5800rpm, hydraulic cam. Catalog says its "an awsome 4x4 performance cam..."
I read some positive user reviews on it but that one might be a bit more than what you want with your application.
Also, consider new pushrods too and maybe rocker arms too because its likely that your entire top end is well worn and when you just replace certain parts you may have failure with the components you skipped.
Old Jul 2, 2013 | 11:49 AM
mdlave's Avatar
mdlave
If I were to replace the heads with stock new assembled D3ves (found a good deal locally) and picked a real mild cam, would spring replacements still be necessary?
Old Jul 2, 2013 | 03:04 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Probably not. That being said, replace them anyway. By "new" I assume you mean they're rebuilt, not new as in NOS still in the box.
On rebuilt heads chances are the springs are used, not new. Springs are cheap, especially when you buy them in a cam kit.
It's just not worth the risk when really good, new springs are so cheap.
Mick1378
Mar 15, 2018 11:10 PM
Fellenz
13
Dec 8, 2013 11:34 AM
MikePacey
Mar 1, 2013 11:01 PM
704 dentside man
Jun 13, 2010 02:37 PM
AirSmitty
May 29, 2004 07:12 AM
