351M valve spring question.
Old Mar 1, 2013 | 04:07 PM
MikePacey's Avatar
MikePacey
So I'm looking at this cam for my '77
JEGS Performance Products 200050 JEGS Performance Hydraulic Flat Tappet Camshafts=
I know that stock springs generally on these engines are set up for .490 lift. Now here's my question. If I stuck with stock springs the cam calls for .030 and .060 rocker shims for correct lash clearance. Would that give enough clearance on the spring? Or will I still need to swap springs. I'm brain farting right now. Also the lift of the new cam is .484/.510.
Old Mar 1, 2013 | 08:36 PM
Thunderjet4x4's Avatar
Thunderjet4x4
stock springs are not that great, especially old ones with a new cam. Spend the extra dough and do it right, with new matched springs compatible with the cam.
Believe me, you do not want broken springs, or valve float!
Old Mar 1, 2013 | 11:01 PM
MikePacey's Avatar
MikePacey
Oh I was deffinatly going to replace them, I was curious about the stock spring as I would like to use them with the cam for break in then swap in new. Now I've heard that you can run a big block chevy single spring on these engines. Any truth to that?
Mick1378
Mar 15, 2018 11:10 PM
1978fordxltranger
Mar 20, 2015 11:52 AM
RadioControlGuy85
Feb 25, 2014 08:41 PM
79_effie
May 11, 2012 09:40 AM
f-4x4
18
Aug 18, 2005 05:24 PM
