Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
08 Escape
Old Jun 29, 2013 | 07:49 PM
mexicancan's Avatar
mexicancan
Exclamation 08 Escape
I just did some work on the AC blend door motor on a 08 Escape for a friend. Now the pass airbag light is on. How do I reset this, any help will be greatly appreciated
Old Jul 1, 2013 | 10:51 AM
tomw's Avatar
tomw
I do not think there is a 'reset' sequence to be performed. I think the system checks for weight presence in the seat, and if less than a given mass, turns on the light. That protects small people from being whacked by a powerful airbag that can damage them. There is a switch on the dash you can push to disable the airbag. I thought it was in the same spot as the warning light. Could you have pushed the button when working on the dash, or left that connector loose when you put things back together?
tom
Old Jul 2, 2013 | 04:54 AM
mexicancan's Avatar
mexicancan
Thumbs up 08 Escape
Thank you. Tom I will be sure to check that when I get the truck back.
Old Jul 2, 2013 | 08:28 AM
wptski's Avatar
wptski
IIRC, there was a problem with a connector under the seat. Just unplugging and reseating it cures the problem although it may return later on. Contact cleaner may help as well.
SJMaye
2015 - 2020 F150
Mar 22, 2018 04:54 AM
Golden_F100
13
Dec 23, 2014 09:34 AM
Blacked-Out
Jun 7, 2009 08:27 AM
95Ford4x4
Jul 25, 2007 09:37 AM
