E4OD Case Swap
Old Jul 3, 2013 | 09:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I think something isn't aligned correctly.
Old Jul 4, 2013 | 06:59 AM
danlee's Avatar
danlee
Mark,
I suspect that someone put a '97 or later E4OD/4R100 into a 460 case. If that's the case, then the '97 Digital range Sensor should work. I would hate to change my harness & connector and have the same problem.
Is there a way to determine if the internals are a later version by removing the oil pan?
Old Jul 4, 2013 | 10:40 PM
Mark Kovalsky
Not that I'm aware of.
Old Jul 5, 2013 | 02:57 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Dan, I asked Donnie Medlin to check on that E4OD I saw on what they call the strip line where they disassemble vehicles. I don't know if it is a core or what, but it is a 460 2wd case and is complete.
Old Jul 6, 2013 | 11:11 AM
danlee's Avatar
danlee
I no longer have any forward gears in Drive. I can get the truck going in 2nd, then shift into drive. It will go into 3rd, then just slip.
I jacked the truck up and disconnected the shift linkage. Then I manually put the truck into drive. I lowered the truck and started the motor. I had no forward gear.
I remeasured the voltage on S1 at the transmission and read about 0.86 Volts.
RIKIL
Jul 22, 2017 09:34 AM
horsez2go
Sep 14, 2014 05:54 AM
N$$
Dec 23, 2013 03:18 PM
gerhard
Jun 25, 2005 07:42 AM
