transfer case swap
Old Jun 24, 2005 | 12:56 PM
gerhard's Avatar
gerhard
transfer case swap
Is It possible to put a transfercase of an 1983 C6 4x4 transmission behind a 1991 E4OD 2wd transmission. <!--IBF.ATTACHMENT_16461-->
<!-- THE POST -->
Old Jun 25, 2005 | 07:42 AM
RTM's Avatar
RTM
The output shafts on a 4x2 trans and a 4x4 trans are different lengths so no you can not bolt a t-case on the back of a 4x2 trans unless you swap out the output shaft with the correct one and buy the rear adapter that is needed on a 4x4 trans. I believe the adapters are different from a C6 to an E4OD as well.
