transfer case question
Old Jun 28, 2013 | 10:55 PM
bcaughhorn's Avatar
bcaughhorn
I tried to search the forum but my phone wont for some reason.
What is the electronic piece on the transfer case called? My 4wd hasn't worked since I got my truck. Its time to get the ol girl back in shape
Old Jun 28, 2013 | 11:21 PM
BrandonT71's Avatar
BrandonT71
Think you might be referring to the "gearmotor encoder" with drives the rotary cam switch which in turn moves the mode and range forks. Are you sure you have no vacuum leaks at the hubs and a properly operating PVH, and are you throwing any codes related to 4wd? I only ask 'cause my truck was throwing P1876- 2wd shift solenoid fault and its looking like it might be the PVH.
Old Jun 29, 2013 | 01:23 AM
bcaughhorn's Avatar
bcaughhorn
Last time I checked it didn't have any codes. I have already changed the vac lines. When I turn the switch nothing happens. The dash light doesn't come on
Old Jun 29, 2013 | 10:00 AM
BrandonT71's Avatar
BrandonT71
Huh, nothing, nada, zip. Have you checked the ESOF switch on the dash? Per the diagram I got from Tugly's link of goodness, resistance between pins 2 & 3 of switch for each mode respectively, 3.9K ohms, 1.1K ohms, 360 Ohms. Seeing as how nothings happening, lets start with the User input, the switch. I suspect that the GEM is not receiving the input.
Old Jun 30, 2013 | 12:00 AM
cory5517's Avatar
cory5517
That happened to me before. Try removing the ESOF relay and clean with contact cleaner
Old Jun 30, 2013 | 12:02 AM
bcaughhorn's Avatar
bcaughhorn
Ill try that tomorrow
Niteman9
May 3, 2015 07:57 PM
dante27
Dec 8, 2012 05:17 AM
kaderab
1997 - 2003 F150
Dec 30, 2007 10:54 AM
95Ford4x4
Jan 10, 2007 04:03 PM
A.FRY
Oct 24, 2006 10:37 PM
