Transfer case switch
Old Jan 10, 2007 | 12:33 PM
95Ford4x4's Avatar
95Ford4x4
Question Transfer case switch
i've got a manual shift borg warner 13-56 tcase and need to replace the switch on the front side that tells if you are in high or low range. aparently it is a dealer item but i think the guy looked up the wrong thing cause he said it was over $200. i believe he was quoting me something for an electronic shift because i know i could by that setup for that kind of money and i just can't believe that a simple 2 lead switch is so high. can anyone shed some light on this and give me a part number and cost??? i have a 95 f150
Old Jan 10, 2007 | 03:10 PM
gustang818's Avatar
gustang818
$200 is outrageous even for the stealership. Other sources for the indicator switch could be from a junkyard or rebuilder of transfer cases. This catalog for Motive Gear (division of Midwest Truck & Auto Parts Inc) has an exploded diagram of the BW1356 transfer case at p. 207 and the switch is listed as #33. Their parts # listing for the 4wd indicator switch on p. 208 is Midwest part # 1300140007. http://www.worldamerican.com/Catalog...s_Tcase_LD.pdf
Try giving them a call 800 934 2727 if you can't find anything locally.
Old Jan 10, 2007 | 04:03 PM
95Ford4x4's Avatar
95Ford4x4
Thanks, yeah even the guy at the counter said that was crazy, i was planning on running to some junkyards in the next couple of weeks, but thought i would ask around. i'll try that link and call and see what i can find out.
preppypyro
31
Mar 5, 2025 03:54 PM
Rulebreaker
18
Oct 27, 2012 07:41 PM
corndogjim
May 13, 2011 12:45 AM
mdyster
Dec 4, 2005 12:05 PM
CNTHOR
Jan 11, 2002 11:07 PM
