Truck dies while driving
First I replaced the fuel pump because I didn't smell any gas in the carb after trying several times to restart it. Then I replaced the ignition module and coil because I thought I may have had a loss of spark. When I replaced the furl pump, I also found the fuel pump eccentric had fallen off. I tightened that back down and put everything back together. The timing chain looks good and has been replaced before.
I also occassionally have issues starting it when it is warm. It will have ha hard time starting and sound like the starter is only moving in half turn increments. I figured that the timing must have somehow gotten messed up so I retimed it correctly and that fixed my issue...for a few days. Now I can barely shut it off to put gas in and restart it...why?
Finally I have one more issue. Today while I was driving down the freeway I was doing 70 mph and it was running pretty well. However when I went to step on the gas a bit more (pedal almost to the floor) to try and shift lanes, the whole truck bogged for a split second, then revved really high like it down shifted and got stuck in second gear, then began just coasting with no transmission or power to the wheels. The engine was still running. Just before the truck came to rest the engine cut out and died and wouldn't restart. 3 hours later I had someone take a look at it and it started up without an issue and drove home. What was that all about?
I have now re tuned the carb and it seems fine. It still boils a bit of gas as does the fuel lines, but I wouldn't think that is what's causing my issues is it??
Have you checked to make sure your choke is adjusted properly? A stuck closed choke can cause problems.
If you have gas boiling in your fuel system, you may very well be dealing with vapor-lock.
