Over heating way bad.....
Old Jul 9, 2013 | 05:50 AM
  #31
tjustice's Avatar
tjustice
Originally Posted by chewedtoothpick
It keeps sounding more and more like a sensor problem. Pull the ECT sensor and check it for any accumulation of silicate or rust.
Heading to do that now.. Sure hope that's all it is.....
Old Jul 9, 2013 | 10:29 AM
  #32
BPofMD's Avatar
BPofMD
Veteran: Navy
Originally Posted by tjustice
Ok made it home today, finally got to truck. after 11 days of sitting, the EOT 84, ECT 84 outside temp was around 80. Drove the truck about mile and a half to the house, from start up to the house, no idle time straight driving 35mph, EOT 140 and ECT 180.....Did notice the turbo sounded way different like has a bad leak with a whistle sound....
Check all the boots for air leaks too....sounds like one is leaking with that whistle!
Old Jul 9, 2013 | 02:44 PM
  #33
tjustice's Avatar
tjustice
Boot blew off..... whistle fixed.
Old Jul 9, 2013 | 02:45 PM
  #34
tjustice's Avatar
tjustice
Fan wires for whatever reason was cut by the fan, this I found just a lil bit ago....
Old Jul 9, 2013 | 03:12 PM
  #35
npccpartsman's Avatar
npccpartsman
Get hold of your fan and give it a wiggle. Usually if the fan gets the wires either it's from the fan wiggling or the harness got loose. I know you just recently replaced your water pump but it still may be a problem.
Old Jul 9, 2013 | 04:21 PM
  #36
tjustice's Avatar
tjustice
New water pump arrives tomorrow at 4:30. No more plastic.....
Old Jul 9, 2013 | 04:54 PM
  #37
npccpartsman
Was the fan wobbling?
Old Jul 9, 2013 | 05:22 PM
  #38
BLADE35's Avatar
BLADE35
Originally Posted by BLADE35
Sounds like a Fan Died
I was curious too
Old Jul 9, 2013 | 06:28 PM
  #39
tjustice's Avatar
tjustice
To be honest, I didn't even check it. I found the wires and started taking off. I know it was snug, busted knuckles getting it to break lose.
Old Jul 10, 2013 | 02:51 AM
  #40
04badford's Avatar
04badford
Make sure this time ,use some zip ties or OEM clips . also check out all other areas of wire harness for Chaff.
Old Jul 10, 2013 | 02:23 PM
  #41
tjustice's Avatar
tjustice
Impellar on water pump was cracked, less than 10,000 miles on it.
Old Jul 10, 2013 | 03:31 PM
  #42
npccpartsman
What brand was the pump?
Old Jul 10, 2013 | 06:46 PM
  #43
tjustice's Avatar
tjustice
Came from local Ford Dealer.....
Old Jul 10, 2013 | 06:48 PM
  #44
npccpartsman
If it's less than 12 months old it's still under warranty.
Old Jul 11, 2013 | 10:29 AM
  #45
tjustice's Avatar
tjustice
Well missing some pieces off 5 impellars on the water pump when took out.....Now how to I locate the missing pieces????
