Over heating way bad.....
Old Jun 27, 2013 | 07:15 PM
tjustice's Avatar
tjustice
2005, 4" exhaust turbo back, egr delete, egr is plugged in, SCT Live wire, Tuned FICM, Sinister coolant filter, Head Studs, OEM Gaskets, (EGT, Trans, Boost Gauges), SG-2....
ICP & IPR appeared to be operating in normal limits
ECT 244 when I shut it off
EOT 215
Coolant was just flushed and changed to John Deere = to the CAT stuff
Water pump replaced about 10k ago
anything else??????
Old Jun 27, 2013 | 07:16 PM
diesel_dan's Avatar
diesel_dan
Originally Posted by 69cj
When you start over heating on a major grade, drop the speed down to 55 and pull the gears into 3rd. That is also while in tow/haul mode. The temps should drop dramatically within minutes. Use your gears instead of engine and torque. They are designed to be used together.
Don't actually need to use T/H once you start manually shifting out of D (this is direct from Mark K. from a thread several years back, where he gave me some schoolin')
Old Jun 27, 2013 | 07:34 PM
tjustice's Avatar
tjustice
Also did scan for DTCs didnt throw any...
Old Jun 27, 2013 | 07:47 PM
chewedtoothpick's Avatar
chewedtoothpick
What is are your ect and eot after a good long (12+ hours) cold soak? The fact that your ect is so much higher than your eot says there is a good chance that there is a problem with the sensors...
Do you have an aftermarket air-to-oil cooler?
Old Jun 27, 2013 | 08:00 PM
04badford's Avatar
04badford
Tjustice, I would take a look at all your pullys maybe one is locking up also could be fan clutch do you hear a sqeal noise,
Old Jun 27, 2013 | 08:25 PM
tjustice's Avatar
tjustice
Factory oil cooler... generally after a soak they are real close to the outside temp
Old Jun 27, 2013 | 08:26 PM
_Me2_'s Avatar
_Me2_
My thought as well.
Old Jun 27, 2013 | 08:39 PM
chewedtoothpick
There is something that doesn't add up, because once your truck is up to temp, it should be very infrequent that your ECT is higher than your EOT, and not by that much.
As a troubleshooting step, I believe you can swap the sensors, we want to see if the temperature follows the sensor or the medium. Please though, can someone verify whether or not you can swap the sensors?
Old Jun 27, 2013 | 08:52 PM
BLADE35's Avatar
BLADE35
Generally if the sensors are there around the same temperature as ambien temp they are all okay
But you also need to watch them at the truck heats up and make sure that they do not jump around This temperature rise should be steady
Old Jun 27, 2013 | 09:05 PM
tjustice's Avatar
tjustice
They generally rise together, water temp first, then the oil catches and then passes.
Normal operating temps vary from EOT 196-204.....ECT 192-200....They stay pretty close to that. Even pulling today, there was never more than a 10-15 degree difference, until the ECT went way up and wouldn't come down.
Old Jun 27, 2013 | 09:06 PM
mhoefer's Avatar
mhoefer
Can you hear the fan engaging, increasing speed and going to full on? My guess, because he says the water pump is replaced, and the thermostat is replaced, is the viscous coupling drive or the wires to it are fried. Since he has an sg2 he should see full doran rpm by about 218 or 219 degrees right?
Old Jun 27, 2013 | 11:58 PM
_Me2_'s Avatar
_Me2_
I would suspect that the problem just started, then. The oil is cooled by water, so if the water temp is consistently high, the oil temp is not going to sit at 215. See what happens in the morning after a cold soak.
Old Jul 8, 2013 | 07:55 PM
  #28
tjustice's Avatar
tjustice
Ok made it home today, finally got to truck. after 11 days of sitting, the EOT 84, ECT 84 outside temp was around 80. Drove the truck about mile and a half to the house, from start up to the house, no idle time straight driving 35mph, EOT 140 and ECT 180.....Did notice the turbo sounded way different like has a bad leak with a whistle sound....
Old Jul 8, 2013 | 09:25 PM
  #29
Rusty Axlerod's Avatar
Rusty Axlerod
I agree with the guys above thinking it's a sensor. I haven't had to swap them myself but it's been posted many times the two sensors are the same part number. They'll swap right out.
From the Motorcraft Parts Store. 24 Hour Ford Motorcraft Parts Store!
#3C3Z19884AA Ford Motorcraft Engine Coolant Temperature Sensor
Part Description: Motorcraft #SW6052
2003-2010, 6.0L & 6.4L Powerstroke Diesel, Used As Coolant Temp Sensor And Engine Oil Temp Sensor On Some Applications, Also Used As Fuel Temperature Sensor.
Old Jul 9, 2013 | 12:16 AM
  #30
chewedtoothpick
... there was never more than a 10-15 degree difference, until the ECT went way up and wouldn't come down.
It keeps sounding more and more like a sensor problem. Pull the ECT sensor and check it for any accumulation of silicate or rust.
