Park switch
Old Jun 26, 2013 | 04:49 PM
roadapple's Avatar
roadapple
Park switch
Once in awhile I can't get shifter out of park?
Old Jun 26, 2013 | 05:23 PM
BLADE35's Avatar
BLADE35
Set the E-Brake with Transmission IN neutral and let truck rock to where the Parking brake holds it then shift into Park
This is how I do it cause I don't like all the Weight or force resting on the Parking Prawl itself
When the trans shifted to park and the truck rocks alittle to where the Trans Parking Prawl Holds it then they are Hard to get to release with too much pressure on it
Sometimes helps to to wiggle the steering wheel back and forth to get it to release as well
Old Jun 26, 2013 | 05:33 PM
roadapple's Avatar
roadapple
Thanks, it's kind of a new problem but I'll try it next time.
Old Jun 26, 2013 | 05:45 PM
BLADE35's Avatar
BLADE35
Im not saying there isn't a problem it could be hanging up
There is a Brake Switch that lets it shift when brake pedal is depressed that could go out
But if you notice it tends to get stuck when parked on a slope then its probably the pressure thing
When the truck rests its weight on the prawl theres about 4 Ton resting on it Lots of Force I guess
Just watch it and when it don't want to shift take note of Surroundings see if on a Incline/hill
We can check into the switch if the condition persists or locks up when Leval parked
Old Jun 26, 2013 | 06:55 PM
04badford's Avatar
04badford
solenoid assembly=f2DZ-3Z719-A , had mine replaced back in 08 found that the solenoid was sticking
F350Man79
Oct 10, 2022 10:12 AM
Brackett127
Sep 26, 2012 08:39 PM
marragtop
Dec 28, 2009 04:54 PM
ErnieX
Escape & Escape Hybrid
Jun 13, 2008 07:50 PM
I'm John
Aerostar
Sep 13, 2003 09:32 AM
