1978 - 1996 Big Bronco
Mojave Trail
Old Jul 2, 2013 | 01:49 PM
memphis88's Avatar
memphis88
So far I haven't had any issues with my 302 yet. Granted it has had to do a bit more work to get moving, but once it's moving she has no problem doing what i tell her to. Except for sand, I took her down to Pismo and was playing around on the dunes and i slid down on the driver side into soft sand. A couple hours of digging and she drove right out.
Old Jul 2, 2013 | 02:18 PM
Encho's Avatar
Encho
The Southernmost Mod
Air down the tires next time (to 15-20psi) and you won't need to dig yourself out.
Old Jul 2, 2013 | 03:18 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
I aired mine down to 18psi both times I was there, and had no problems, makes a big difference
Jim
Old Jul 2, 2013 | 11:51 PM
memphis88's Avatar
memphis88
I had it down to 15 psi each tire. Just extremely soft sand.
Old Jul 5, 2013 | 02:19 AM
memphis88's Avatar
memphis88
Another question. With a 32 gallon tank and being in 4 high pretty much the entire trip (possibly in 4 low part of the time) would I be safe with two 5 gallon Jerry cans? Also ill probably running lower psi in my tires as well.
Old Jul 5, 2013 | 11:23 AM
Encho's Avatar
Encho
If the terrain is rugged you have no need to lower the tire pressure. You said the trail was 150mi long, then you should be fine even without the extra gas, but it's good to have it available.
Old Jul 5, 2013 | 12:12 PM
Nighteyez's Avatar
Nighteyez
I agree with Encho, no need to lower tire psi if it is not sand or loose dirt. I just went four wheeling in Ballinger OHV and did not lower my tire psi once. As for the extra gas, you probably will not need it, but again, it is better to have and not need, then need and not have, besides, maybe one of your buddies will need it. So I would take it just to be safe.
Jim
Old Jul 10, 2013 | 07:18 PM
memphis88's Avatar
memphis88
This one question is a bit off topic. if I wanted to weatherproof the inside of my truck I thought about getting a rhino lining kit which I've heard works really well offroading vehicles. A cheaper way I've heard is using the spray on bedliner like the rattlecan stuff works really well too. Anyone done this out know anything about it?
Old Jul 10, 2013 | 08:04 PM
Encho's Avatar
Encho
Diesel Brad has done some great work with Rhino Lining, I would advice you to do it right the first time, some vinyl flooring should work too if done properly. I wouldn't use anything from a rattle can and expect good results.
Gary Lewis
May 10, 2016 09:53 PM
JERSEY MUD
Mar 20, 2011 11:04 PM
THE KING
Jul 23, 2007 05:59 PM
iwannabebig
Bronco II
Apr 2, 2004 10:21 AM
BroncoMTR
Sep 13, 2003 09:18 PM
