7.3 Toast?
Looks like I very, very stupidly toasted my '89 F250 7.3 diesel.
Few weeks ago my radiator sprung a leak. Took it out & to a radiator shop. Guy there said there was a cracked seam and looked like several plugged tubes. He said it wasn't worth fixing, buy a new radiator.
I went home and laid it flat and filled with muriatic acid for a couple hours. Flushed it out with water & then baking soda. Soldered the seam, rigged up a way to pressurize the rad. No leaks. Reinstalled, ran some flush stuff thru the system, filled with SCA pre-charged AF. No leaks. I congratulated myself on saving about $400.
Last week I had to go to an energy fair trade show I exhibit at every year. Loaded up my trailer the night before I had to leave, and then noticed a tell-tale puddle under the truck. Grump, leaking AF. Dumped in a can of stop leak, looked like it quit leaking.
Next morning I set out to drive 150 miles to the fair. Stopped for diesel and saw another squirt & puddle. %$#@!!!! I should have given up and limped home at this point, but I had paid like $500 to be an exhibitor and just wanted to get to the fair and get set up. So I dumped in another can of stop leak. Thought it quit, so I kept driving.
The temp gauge usually reads between N & O, but it was running more in the R to M range. I figured well, it's warm but still in the NORMAL range. The needle started creeping up to A. I sighed and turned on the heater, and it seemed to stabilize.
Check engine light came on, now the needle said A to L. I cranked the heater to max and the light went out and the needle went back to A. Kept driving. Then the light came on and the needle pegged off the scale. I pulled over and shut it off and let it cool enough for needle to drop to R and light to go out. I did not let it cool enough to take the cap off and check fluid, though. Duh.
To make a long story short, I drove the poor truck for three hours, and got to my destination. When I shut it off and let it sit for a while, I added about 6 to 8 quarts of water (31 qt system). Then it would not start. Cranked until the battery was too low. A couple of friends tried jumping me, I sprayed some ether, no go. Put a charger on it overnight. Next morning batteries completely charged, but now the starter just went "click" and it didn't turn over at all.
I wound up calling AAA and it cost me $200+ to get the truck hauled 150 miles back home.
Various people have offered me theories about how bad the situation is. One guy said the ether caused vapor lock and fried the starter. Others said I may have warped a head and/or blown a gasket and have AF in the cylinders keeping the engine from turning (although I don't see milkiness on the dipstick). And/or have serious cavitation issues.
So my question is: is there any hope to resurrect this engine? If I need a new engine, I will probably be looking for a different truck, as this one is pretty rusty and has no shortage of other issues.
I got my son to pull the truck. Filled the radiator, got 'er rolling and popped the clutch to see if the engine would turn over. It did, and started. Drove er up and down the road a bit. Seemed to run good, sounded OK, although the temp gauge was creeping up.
Back home, I drained the oil. No water or AF in the oil, swished a magnet around in the bucket, no obvious metal shreds.
I took out the starter and bench tested it. Solenoid kicks in, but shaft & gear don't turn. Called the place I bought the starter, they said it has a lifetime guarantee, they will replace it.
So, I guess I am going to gamble that my 7.3 has some life left in it (it's about 190k miles). I'll replace the starter and radiator and also the worn ball joints, and keep driving it.
I ordered a $100 used radiator from a salvage yard, but they called back and said when they went to pull it, it was junk, sorry. Now I am thinking I don't wanna experience the leaking radiator blues again, maybe a new one is a better plan.
The OEM radiator is brass and copper. Looks like most of the less expensive radiators out there are aluminum with plastic tanks. I see on Rock Auto site one of those for about $268. Copper/brass one is $382.
Anybody have any advice/experience on the aluminum/plastic vs copper/brass?
Almost 5 yrs later, and neither one has had any cracking issues (No overheating either).
So I'm not gonna bash plastic and aluminum for doing its' job.
my advice would be bite the bullet and go for the brass/copper.
i am on my second radiator in my 88 at 496,000 miles. the first one last around 350,000 miles before the top tank rotted off. the replacement was a modine brass/copper.
Just was saying that not all plastics are made equal.
I highly recommend the Anti-Cavitation additive to the coolant, or make sure to get one that lists the A-C stuff in its' ingredient list.
First I ordered a used radiator from a salvage yard. They had to remove it from the truck. They called back the next day and said sorry, the only one we have is junk.
Yesterday I ordered from rockauto.com a brass/copper Vista-Pro 432194 rad. Listed $382, but came to $473 with shipping and tax. Today they called me and told me this unit was out of stock.
So, back to the drawing board. I've been doing some more online research. A different ford truck forum had a long thread offering opinions on advantages and disadvantages of various kinds of radiators. I now have a slightly better idea of my ignorance on the subject.
I learned that different radiators have different numbers of rows of cooling tubes and different numbers of fins per inch, which the online descriptions may or may not tell you about. The various posters of course, had widely differing opinions on what to look for.
I looked at a bunch of rads on eBay and at the moment am leaning toward an all-aluminum three-row with tig-welded Al tanks (not plastic). It claims to be designed for racing and have 40% more cooling capacity than stock, but sells for $208 with free shipping. For a few bucks more I could get the same unit with two electric fans attached to it. If they would fit with my stock belt driven fan in place, i like the idea of just wiring them to a switched relay so i can flip them on if I am climbing a hill and the belt driven fan doesn't cool enough.
I also replaced the air and oil filters. Truck seems to be running great.
I also just threw $1111 into new ball joints, new front tires and alignment. I may have invested more than this rusty '89 F250 is worth, but after shopping for a replacement truck, I concluded that i could spend a hell of a lot of $ for a truck with a lot more miles than this one (190k).
After all this, I now have to replace a driveshaft U-joint, but I am going to start a new post on that issue.
I can fix a lot of stuff for what a new truck payment and insurance would cost every month.
Robert
