the big decision
Old Jun 25, 2013 | 07:59 PM
youngf1owner's Avatar
youngf1owner
the big decision
i need ur guys addvice. My 48 (which i will upload pics this weekend) has small surface rust spots the largest about the size of a quarter of a hand. this is my only ride, should i sand it down and repaint it(which i really dont have the time to do it fast cause i play 3 sports and work in the summers) so should i take care of that now or wait 2 years when i graduate from hs?
Old Jun 25, 2013 | 08:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Drive it, enjoy it, you almost certainly don't have the skills or tools to do it right (no offense). You'd need a MIG welder and be practiced at welding thin steel. When you post pics we can judge better. In the meantime, concentrate on school, it's much more important!
Old Jun 25, 2013 | 08:32 PM
AXracer's Avatar
AXracer
Surface rust is where the protective paint has deteriorated from weather, wear, or other damage exposing the bare metal underneath to moisture forming a coat of rust that does not penetrate into the metal. Surface rust (some refer to it as patina) is different tan corrosive rust that eats holes thru the metal. Corrosive rust usually is due to moisture combined with corrosive salts (found in mud, acid rain, road salts) remaining in contact with the metal for an extended length of time.
Surface rusts acts much like paint, if it stays dry it will not progress into the metal very quickly, so if what you have is surface rust, there is no great urgency to do anything about it. If it concerns you, rub off the loose rust with a clean coarse cloth like burlap, and give it a coat of rattle can flat clear right over the surface rust. That will protect it for a few years or at least until you get done with school.
Old Jun 25, 2013 | 09:09 PM
52 Merc's Avatar
52 Merc
I agree with the others; don't be overly concerned with it. Surface rust is generally benign. Not hurting anything. Even if you had rusted out areas, like in fenders or cab corners, they're already bad and not going to get significantly worse in a couple years since the metal needs replaced anyway. Remember, it took 60 years for your truck to become in the condition it's in, so 1 or 2 more isn't going to make any difference in the big picture. Just get your truck running dependably and safe, and enjoy it until you have time and money to do more with it.
Old Jun 25, 2013 | 09:46 PM
ben73058's Avatar
ben73058
Welcome Aboard Young F1! We are happy to have you here.
Drive it & see how it runs. You & your buddies can have a great time working on your old truck together.
Ben in Austin
1950 F1
Old Jun 26, 2013 | 01:50 AM
Bozworth's Avatar
Bozworth
Welcome to the site YoungF1.
I just read your intro thread, I think that's very cool that you have an F1 at 15 years old.
Do your best with what you have on that rust spot and hit it with some rattlecan primer. Leave it, you'll get to bodywork later on.
Do your research. This site is your #1 source. Whatever you are thinking, it's been done already, and they probably took pictures, or will if you ask.
Get it to stop, start, and steer. Try to ignore all the little details you are going to fix. Try to ignore all the custom work you are going to do later on...Get it to stop, start, and steer first. Drive it for awhile before you start making major changes. (Engine, suspension, drivetrain, etc.)
Don't get hung up with the "let's make it pretty" idea. That comes later. You'll waste alot of time and alot of money if you start there. Believe me.
Good luck, post lots of pictures of your build!
Old Jun 26, 2013 | 12:32 PM
arctic y block's Avatar
arctic y block
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
jvmcc
Aug 26, 2014 07:54 AM
cdawley4
Paint & Bodywork
15
Apr 20, 2010 11:31 PM
sum_weirdo
18
Jun 20, 2009 12:35 AM
gander801
Paint & Bodywork
Apr 18, 2007 06:16 PM
FORD TRUCKIN 83
1983 - 2012 Ranger & B-Series
Oct 1, 2002 07:42 PM
