Exhaust pressure sensor
Old Jun 24, 2013 | 05:10 PM
L121andrew24's Avatar
L121andrew24
I have a 2005 f350 diesel 6.0, the code for the exhaust pressure sensor and turbo under boost came on, I was looking for a DIY on cleaning and changing the eps, I'm not sure where it is. Any help would be appreciated
Old Jun 24, 2013 | 05:53 PM
redford's Avatar
redford
FTE Leadership Emeritus
Moving request for assistance to 6.0L Power Stroke forum.
Old Jun 24, 2013 | 06:03 PM
mustang_309's Avatar
mustang_309
<p>The EBP sensor is located just forward of and below the FICM ( the FICM is the aluminum case with fins on the drivers side valve cover ) and is connected to the front of the drives side exhaust manifold via a tube. Remove the sensor and run a piece of weed whacker line or a stiff pipe cleaner through the tube into the exhaust manifold, make sure the engine is cool before doing this. And I just use compressed air and blow out the end of the sensor.</p> It is also a good idea to pull and clean the MAP hose and clean the hose nipple at the intake, The MAP sensor is located just above the evaporator housing on the passenger side and is connected to the passenger side intake manifold via a rubber hose.
Old Jun 24, 2013 | 07:05 PM
04badford's Avatar
04badford
X2 on that also and we just went thru this most EBP sensers are on a plate attatched to the Thermostat housing 05/06 some we moved to the location that Mustang noted( why cant ford leave well enough alone)
Old Jun 24, 2013 | 07:39 PM
L121andrew24
Thanks for the help! Is low boost common to the ebp sensor, or is my turbo failing?
Old Jun 24, 2013 | 07:46 PM
BLADE35's Avatar
BLADE35
On 05+ yes low boost is common to a Bad EBP sensor
You need gauges to see live sensor values to make shure whats going on here
What was the Exact DTC you got??????????????????????
Old Jun 24, 2013 | 07:54 PM
04badford's Avatar
04badford
yes the connections that mustang was refurring to would cause boost issues and there not that hard to take off and clean up this will help ,but when you take the connections off IT WILL throw a code , but don't worry erase them and start fresh
MAP connection to Intake the nipple and intake hole gets clogged
IAT2 senser , will get sooted pull and clean
EBP tube that goes to the Manifold some times gets blocked
Remember to use Carb cleaner and a plumbers flux brush AND don't get the electrical side of the sensers I wrap with an old sock
and ware your safety glasses that stuff burns like
Old Jun 26, 2013 | 11:17 AM
L121andrew24
I still can't find it, and I couldn't find anything online, I think I'm going to go buy a repair manual
Old Jun 26, 2013 | 11:25 AM
mustang_309
Here is the link to the 2005 running changes PDF in the tech folder that shows the old location of the EBP sensor and the new one, https://www.ford-trucks.com/ford-man...ges-Update.pdf it is on the drivers side of the engine.
Old Jun 26, 2013 | 04:18 PM
L121andrew24
Can I get to it with out moving anything out of the way?
Old Jun 26, 2013 | 04:22 PM
mustang_309
You can see it without removing anything but to remove it for cleaning removing the air filter would give you some room.
Old Jun 26, 2013 | 04:30 PM
L121andrew24
alright I'll try tomoro! Thank you!
Old Jun 26, 2013 | 04:39 PM
mustang_309
You're welcome
Headviking
Jan 12, 2014 12:59 PM
Peace2Peep
Oct 3, 2013 09:31 PM
Fordman_95
Sep 26, 2013 02:56 PM
samsdad02
Aug 11, 2013 06:45 AM
wgw
Dec 15, 2004 05:12 AM
