Coolant
Old Jul 10, 2004 | 06:32 PM
Tasslehoff13's Avatar
Tasslehoff13
Coolant
Since I've gotta change the water pump I'm planning on flushing out the old cooland and changing over to Evans waterless coolant. I'm just wondering about the flush out process with the water pump removed os should I flush her out before I remove the pump. I'm also not sure howmuch I need for the motor. 95 7.3PSD. Thanks for the help guys.
Old Jul 10, 2004 | 11:47 PM
Kwikkordead's Avatar
Kwikkordead
You should flush it out with the old waterpump. There is lubricants for the water pump seal that is added to antifreeze. Flushing out with water removes the lubricants from the coolant and your brand new water pump seal takes a beating.
