Replacing carrier bearing
Old Jun 24, 2013 | 07:42 AM
tonefordays's Avatar
tonefordays
Hey guys,
I'm getting ready to replace the carrier bearing on my driveshaft, and I want to make sure I have all the tools I need "before" I take everything apart. I was wondering if someone could tell me what size the nut is that holds on the yoke to the shaft. I just want to make sure I have the right size socket available.
Thanks!
Old Jun 24, 2013 | 09:31 AM
Yahiko's Avatar
Yahiko
No nut. you remove the U-joints to drop the shaft and then
remove the boot that covers the slip joint and you there.
Press the old one off and the new one back on. You may
need a boot kit and I would use the Ford XG-8 grease.
Motorcraft P/N XG-8 PTFE aka Teflon®
It's blue and seems to be thin but works very well.
Sean
Old Jun 24, 2013 | 10:12 AM
tonefordays
Thanks!
Old Jun 24, 2013 | 11:25 AM
69cj's Avatar
69cj
Sean
If you can't get that, any auto parts house will have the blue marine grease. It has small fibers making it cushion quite well.
Old Jun 24, 2013 | 12:00 PM
run6.0run's Avatar
run6.0run
It's a 12mm 12 point to remove the yoke from the transfer case.
Old Jun 24, 2013 | 12:12 PM
tonefordays
Thanks guys, sounds simple enough. We'll see........
Old Jun 24, 2013 | 05:27 PM
cheezit's Avatar
cheezit
if you have no idea how to do this job look at taking the drive shaft to any local machine shop.
mark were every thing goes together as misorantition will cause a vibration.
Old Jul 1, 2013 | 09:23 AM
tonefordays
So I swapped out the carrier bearing this weekend, I didn't have a puller long enough to reach the bearing due to the length of the spline shaft, so I ended up heating up the bearing and tapping it off. The bearing itself was still in pretty good shape after 74,000 miles, however the rubber surrounding the bearing was toast. I was suprised to see little to no grease on the spline, I would have expected to see a little more on there. I pressed the bearing and dust cap back on and reinstalled the shaft. I can definitely tell the difference, no more "thump" underneath the truck when I throttle up.
Thanks to everyone for the pointers!!!
danskool
Sep 4, 2018 10:40 AM
jim6liter
Nov 13, 2014 01:53 PM
powerstroker100
27
Jul 30, 2010 06:10 PM
Daviddc114
Oct 18, 2006 06:19 AM
muzz3256
Jun 15, 2003 03:21 PM
