Were under-frame air deflectors only on F150's?
Were the steel air deflectors (that bolt under the chassis rails, below the radiator) only installed on F150's? Those I've seen have been.
If so, did the F250/350 sit too high to benefit from having deflectors, or were they also installed on heavier trucks?
I have one on a dead F150, that I would put onto my F250 if it is any aerodynamic gain (anything to help ).
Thanks
Thanks
I have sway bars - well, I've actually taken them off to ease the hard riding.
The front sway bar mounting brackets used the same holes to attach to the rails that the deflector does - so you can only have one or the other.
oneowner83 - it does look like a small skid plate, but only a few inches wide.
This is just a 2wd truck though (so, on-road), the other one I've seen was too.
Gary, I'll try & get a photo.
Bill - Thanks! You, as always, did it better than I would have. And you also captured the piece I thought Ken was talking about:
- 5C128 in the illustration, which is "Cross member (frame front lower)" from the text section.
- %001A06, aka "Air Deflector". I wonder what help it gave on the MPG? Worth adding?
Thanks very much Bill.
So as Blue Rebel said, it's not designed as an air deflector.
I wonder how much gain there would be in mounting a deflector plate onto it, pushing the airflow down below the untidy underside of the truck? Probably it would just come back up off the road in time to be caught by the rear axle & bed.
