Steering, starting and cooling
Old Jun 23, 2013 | 11:16 AM
77460ford's Avatar
77460ford
Well my automotive A.D.D. was in full swing; I was heading to a friends shop to hit the frame with the grinder/flapper wheel and apply some POR15 and then it started. First I go to start the truck and it makes a terrible noise, the starter has died. Ordered a mini starter for a '95 F250 which will spin any compression big block and has a lifetime warranty. On the drive up to the shop the play in the steering wheel reached my breaking point, everything has been changed except the steering box and a call to redhead had a rebuilt unit at the shop in two days. When on the hoist I discovered the rad hoses were getting pretty soft so ordered some stainless hoses from Summit. Hopefully everything is done this week and I'm beating on it by next week-end. The one positive, I did get the frame painted
Making it easier to reach the frame:
Old Jun 27, 2013 | 08:43 PM
77460ford's Avatar
77460ford
Got the upper rad hose swapped to a stainless flex line, and the lower replaced with a new rubber one (2" flex is not available). The redhead steering box was a straight forward swap and the truck drives like new, all traces of wander are gone. The starter I'm still fighting with but I'm getting close.
Old Jun 28, 2013 | 08:32 AM
wotan's Avatar
wotan
Great looking truck. What size tires are you running?
Old Jun 28, 2013 | 01:13 PM
Sooper Camper's Avatar
Sooper Camper
what spoiler and visor are those?
Old Jun 28, 2013 | 09:36 PM
77460ford's Avatar
77460ford
Thank-you; tires are 35" x 12.5" Baja Claws, the sunvisor and racerback fairing are Lund.
Old Jun 29, 2013 | 12:19 PM
Sooper Camper
thanks, i dig that look. how permanent is the racerback? can it be taken off to run a slide-in camper?
Old Jun 29, 2013 | 01:40 PM
77460ford's Avatar
77460ford
Unfortunately it's a semi permanent install, screwed to the cab.
cjp97-7.3
May 1, 2016 06:55 AM
quakerj
Nov 20, 2014 05:24 PM
Shifty718
Dec 18, 2009 06:48 PM
wls
May 30, 2003 06:14 AM
jdharris5
1997 - 2003 F150
Feb 19, 2003 09:27 AM
