Sloppy steering
Old Jan 13, 2009 | 09:55 AM
Shifty718's Avatar
Shifty718
Sloppy steering
84 F150 4x4 with many many miles. I don't have a tilt wheel, but am experiencing a good quarter turn of play in the wheel. The wheel's got a little of that steering wheel as entry handle slop. I saw an expensive shaft replacement inn LMC. I guess it could be a steering box problem as well. I replaced the radiator frame support, hoping that reconnecting the frame rails would help (did help me pass Maine inspection though)
How do I figure out where the problem lies?
Old Jan 13, 2009 | 11:56 AM
Ken Blythen's Avatar
Ken Blythen
Tightening the steering box adjustment made a dramatic difference to my truck. It involved about 3/4 of a turn. Before that, you had to keep full concentration at open-road speeds to avoid trouble.
But there is a proper procedure to follow, & preload to torque the adjuster up to, or the box can be damaged - the Haynes manual outlines it, also the Autozone site.
You need to pinpoint any tie-rod looseness first (one person rocking the wheel back & forth while another checks each rod-end ) & be sure the box is tight on the frame.
Old Dec 17, 2009 | 11:29 PM
Captain Obvious's Avatar
Captain Obvious
My steering sounded a lot like yours. Had a buddy at Goodyear look it over once I purchased it. It needed a number of things in the front end, new tie-rods, repack the bearings and of course an alignment. Almost done with the tierods.
Old Dec 18, 2009 | 06:48 PM
Franklin2's Avatar
Franklin2
The only way to figure out the worst offender is to get someone to lightly rock the steering wheel back and forth while you look around for play in the shaft, rag joint, steering box, and steering linkages.
