Hinge to hood question
Old Jun 22, 2013 | 06:17 PM
Becky_is_a_66's Avatar
Becky_is_a_66
Happy summer to all (or not depending on your address I suppose),
I am working on Sally's hood at this point; need to redo some spot welds that have popped loose and fix a few cracks in the rear support under the hood skin. On each side there is a threaded block which accepts the hinge to hood bolts; on one side the block slides left and right a bit....on the other side it does not move. I assume it SHOULD move L to R as the hinge is slotted from front to back. Just want confirmation before manipulating the rear support to make the non-moving one move and doing the necessary welding. Thanks for any advice, wisdom, or knowledge.
Old Jun 22, 2013 | 08:01 PM
P38fighter's Avatar
P38fighter
should move Left Right Forward and Back...
Trentonpro1
Feb 11, 2018 01:26 PM
Bluey Zedoff
20
Apr 6, 2016 07:19 PM
rmallow77
Oct 14, 2008 09:08 PM
51PanelMan
May 4, 2007 12:40 AM
reamer
Nov 3, 2005 02:55 PM
