Tranny question
Old Jun 22, 2013 | 12:09 AM
JakeNail's Avatar
JakeNail
Tranny question
Hello everyone,
I'm Jake and new to this site. I have looked but couldn't find an answer to a question I have so I hope someone out there can help me.
I have a 68 f100 with the 360 it has the 4 speed granny low tranny. I also have a 85 f250 chassis with a 6.9 and a c6 with a gear vender. I am wondering if the c6 from the 85 will bolt up to the 360.
Can anyone help?
Old Jun 22, 2013 | 12:24 AM
85e150's Avatar
85e150
Welcome to FTE.
Your '85 oil burner pattern trans will NOT bolt up to your 360 "FE" motor.
Ford uses about 300,000 bell to engine patterns....
Almost every engine series uses a different pattern.
http://en.wikipedia.org/wiki/List_of_Ford_bellhousing_patterns
You can probably get an adapter for the GV to bolt to the 4 speed, but you'll have to talk to the GV folks about that, along with a driveline feller as you will need an adjustment there.
If you just want an automatic, there are billions of FE C6 transmissions around.
Scroll down a bit for bell pattern comparisons. No oil burner pattern, but is is similar to the 385 series pattern, or so I gather from other posts here:
http://www.fordfe.info/Forum/FAQ-Style-index2.html
Last edited by 85e150; Jun 22, 2013 at 09:26 PM. Reason: Forgot the NOT. Thanks ND
Old Jun 22, 2013 | 01:14 AM
JakeNail's Avatar
JakeNail
Cool thank you very much for the info.
Old Jun 22, 2013 | 09:30 PM
85e150's Avatar
85e150
My answer was incorrect. See correction above. Sorry for the error. It's not that I don't know this, I just didn't proof my post. Thanks to Numberdummy for calling this out.
I'm so ashamed....
Old Jun 23, 2013 | 04:11 AM
jowilker's Avatar
jowilker
I'm so ashamed....
You should be for allowing your forgetter to kick in and not check it.
John
$Bruiser$
Dec 24, 2011 01:10 PM
Goodold71
Aug 8, 2004 09:59 PM
ScottJM
Nov 16, 2003 07:18 PM
73-360-f100
Apr 15, 2003 06:44 PM
Jigsaw
May 8, 2002 06:36 PM
