headlight switch
Old Jun 21, 2013 | 04:11 PM
capelo's Avatar
capelo
headlight switch
hello I'm trying to disassemble the switch and I can not get the shot, someone can help me?
thanks
Old Jun 21, 2013 | 04:26 PM
yamagrant's Avatar
yamagrant
Are you tring to get the handle off? If so, I think it may have a spring loaded pin on the back of it. pull the lever till it just stops, push the pin in and the lever shoud come off.Good luck.
Old Jun 21, 2013 | 04:33 PM
capelo's Avatar
capelo
Thanks for responding so quickly, I find that pin I could show
Old Jun 22, 2013 | 04:34 PM
capelo's Avatar
capelo
I have not been able to disassemble the switch, I can not find how to do it .....
Old Jun 22, 2013 | 05:01 PM
70BumpClubCab's Avatar
70BumpClubCab
ok you have a small metal tang that is like a piece of spring steel. you have to use a pair of needle nose pliers to flatten it against the metal piece that braces it and goes up into the switch. once that is pinched flat, you can unscrew the pull **** shaft out of the switch. yes, it is fun. with the instrument cluster out, you can see what you are doing WAY better.. hope this helped!
Old Jun 24, 2013 | 04:27 PM
capelo's Avatar
capelo
Thanks for your explanation, I have removed the switch rod
hooler1
Mar 26, 2018 05:57 PM
Bird-Dog 250
Sep 13, 2015 12:11 PM
VH_Girl
May 21, 2014 07:12 PM
knash0727
Sep 13, 2008 06:04 PM
