headlight switch
hello I'm trying to disassemble the switch and I can not get the shot, someone can help me?
thanks http://midfifty.com/partpics/thumbs/2853-21580.jpg |
Are you tring to get the handle off?:-X22 If so, I think it may have a spring loaded pin on the back of it. pull the lever till it just stops, push the pin in and the lever shoud come off.:-X22Good luck.
Thanks for responding so quickly, I find that pin I could show
I have not been able to disassemble the switch, I can not find how to do it .....
ok you have a small metal tang that is like a piece of spring steel. you have to use a pair of needle nose pliers to flatten it against the metal piece that braces it and goes up into the switch. once that is pinched flat, you can unscrew the pull knob shaft out of the switch. yes, it is fun. with the instrument cluster out, you can see what you are doing WAY better.. hope this helped!
Originally Posted by 70BumpClubCab
(Post 13277303)
