Help with coolant please
Old Jun 21, 2013 | 10:03 AM
CPB1's Avatar
CPB1
Before I do a flush and fill.
Did I get the correct coolant? I was not sure if this is the Cat ELC that some are using.
Thanks
Old Jun 21, 2013 | 10:07 AM
Rusty Axlerod's Avatar
Rusty Axlerod
That's it.
Many different brands but that will work great, same stuff I'm using.
see correction below.
mhoefer's Avatar
mhoefer
I don't think that is the correct stuff.
Old Jun 21, 2013 | 10:10 AM
mhoefer's Avatar
mhoefer
You want this: http://www.toromontcat.com/pdf/ExtendedLife.pdf
Old Jun 21, 2013 | 10:32 AM
T diesel's Avatar
T diesel
You need four gallons of CONCENTRATE elc coolant, not 50/50.
Never mind, I see it's concentrate.
Old Jun 21, 2013 | 10:34 AM
Rusty Axlerod
Ahh...dang CAT labels all look the same. After looking closer I don't see the EC-1 statement on that bottle. Thanks for the catch mhoefer! I'm not at home to check the label and part # but the one I used was clearly marked as EC-1 rated. Sorry OP.
T diesel's Avatar
T diesel
I like International Fleetrite.
Old Jun 21, 2013 | 11:39 AM
chev69ss's Avatar
chev69ss
hey if it helps any I found that my local napa store carried 3 different choices of coolants that matched what we r looking for.the one I chose was made by peak and states on the label that it meets cat ec-1 req. u do have to watch because they also carried diluted ones .this full strength was called final global charge and was phosphate,nitrite,silicate and borate free.Price here in jersey was 27.00 per gal.a little pricey but should be really good for our oil coolers.hope this was helpful good luck I'm heading outside to do mine in right now.
Old Jun 21, 2013 | 01:39 PM
CPB1's Avatar
CPB1
Lets try again.
The local Cat dealer did not have the Cat brand EC-1. She said they have not had any in over a year. They did have the 50/50 mix in Cat EC-1.
Thanks for the link mhoefer. I printed it out and took it with me. It came in handy when trying to explain what I needed.
This is Cat EC-1 rated. You think this is ok?
Thanks everyone for your input.
Old Jun 21, 2013 | 02:33 PM
chev69ss's Avatar
chev69ss
that's exactly what I got.where did u find that in stock just so others who see this post can see where its available.i found it at napa but being a peak product i'm sure others carry it
Old Jun 21, 2013 | 03:39 PM
CPB1's Avatar
CPB1
I got it at Cumberland Truck Equipment in Nottingham Pa. They also have stores in Carlisle and York and throughout Pennsylvania. It's $22.95 a gal. and I got 4 at 91.80 plus tax.
My local Napa store did not have anything Cat EC-1 rated. I also tried another truck parts store, and all they had was 50/50 mix Zerex ELC. I even tried an International dealer, he said he could get the Fleetgaurd but did not have it in stock.
Old Jun 21, 2013 | 04:31 PM
Rusty Axlerod
Let me try again.. Yes that's the type you want. EC-1 rated, silicate fee, concentrated coolant. Again sorry for the mix up earlier. Good luck with the flush, it can be time consuming.
Old Jun 21, 2013 | 05:02 PM
diesel_dan's Avatar
diesel_dan
I couldn't find any OAT (EC-1) coolant at my local Napa stores -- they probably could have ordered it but I was out of time. Some stores carry the Zerex EC-1 concentrate and it is less expensive for some reason like in the $8 to $10 per gallon.
I went with the Peak Final Charge concentrate I got at O'Reilly's (was $26/gal) plus Distilled water. The Final Charge seems to be widely available and the booster that allows the coolant to go 600k/6yrs is not expensive either...
Old Jun 21, 2013 | 05:44 PM
CPB1's Avatar
CPB1
No problem Rusty, thanks for being here. I owe you and many others on this board a couple .
One other question, when you put in the Fumoto valve, what did you use for a washer? I read to use a rubber O ring, but I was also thinking copper washer. I bought the F108N and it comes with gasket.
Thanks
Old Jun 21, 2013 | 07:56 PM
Rusty Axlerod
The hole in the block is 1/2 chamfered for the o-ring and the factory plug is clearanced for the other half of the needed space. The area around the hole in the block is machined also so I think the o-ring from the removed plug or the gasket that comes with the valve. Either should work just fine. I wouldn't worry about chasing down anything special.
I opted for the o-rings and have no leaks.
