VOLTAGE ?
Old Jun 20, 2013 | 07:57 PM
blazer350's Avatar
blazer350
VOLTAGE ?
I CANT FIND A REPAIR MANUAL ANYWARE IN TOWN. I CANT WAIT TO GET ONE IN THE MAIL. SO HERES MY QUESTION WHAT ARE THEVOLTAGES COMING OUT OF THE ALT AND VOLTAGE REGULATOR. ITS A STRIGHT 6 240
THANKS FOR ANY HELP
Old Jun 21, 2013 | 02:09 PM
FECruzer69's Avatar
FECruzer69
I would just check the charging voltage at the battery. Voltage across the battery should be aproxiamately 13 - 14.7 volts @ idle. The voltage at the battery "BAT" terminal of the alternator should be the same or very close to that.
IIRC, the stator "STA" terminal voltage should be about half of the battery voltage.
If you're testing the system and bypass the voltage regulator ( don't do this without the repair manual ), the alternator output should climb to anywhere between 16, 18 or even 20 volts.
I hope this helps.
Old Jun 21, 2013 | 02:50 PM
blazer350's Avatar
blazer350
thanks for your help I will check it out
chasthanhburns
Sep 9, 2015 05:03 PM
rswhitmore
Aug 23, 2015 08:59 PM
1982fordf100
May 18, 2004 10:03 PM
Smitty1019
May 13, 2004 10:49 PM
thuggishruggish3000
Jan 12, 2004 01:56 PM
