76 f100 temp gauge
76 f100 temp gauge
I have a 76 f100 with a 351 c 4v from a 71 mustang. I put in a new temp sending unit for a gauge. now it just reads hot. I tried another gauge cluster same thing . I better give ya some info, I am running a wire from sending unit to the red / white wire in connecter coming from the wires running to fire wall which should be the correct wire.
What is wrong?
What is wrong?
F1SZ-10884-A (replaced DOWY-10884-A & DOZZ-10884-A) .. Temperature Sending Unit-Use with Temp Gauge (Motorcraft SW-2328).
Applications: 1970/96 F100/350, Bronco & Econoline / 1997 F250/350 / Myriad 1970/90's FoMoCo Passenger Cars.
Is it just it just the way i am tapping into the wire? I am taking a wire from the sending unit to the plug from the firewall. It is a 3 prong plug. I am just sticking the wire into the red/white one which should be the correct one.Should I be doing something else also? What are the other wires for in the connecter?
The bottom of the temperature gauge runs out to the block through a RED with WHITE stripe wire. You control the needle swing by varying the resistance to ground. How do you know you have the correct sending unit? How do you know the engine isn't actually running hot? Seems like we're not any farther along than when we started.
If you disconnect the sending unit and turn the key on, does the gauge fall back to the left? If so, there's nothing wrong with the wiring. It's all in the sending unit. I don't know what connector you're talking about.
In the sender there could be a variable resistor (like a fuel gauge) the changes resistance by expansion/ contraction with heat.
By installing a fixed value resistor in series. This might work if the gauge is reading inaccurately on the high side. Many of the older Ford gauges are a little less than accurate by now. I believe there is some adjustment that can be made to the gauge indication itself too, but you better have a steady hand and avoid coffee that day.
