What axles do I have?
Old Jun 10, 2003 | 10:35 AM
X-bus's Avatar
X-bus
It's a 2001 X Limited with the V-10. Do you guys know? Thanks!
Here's my rig.
Noah
Old Jun 10, 2003 | 10:51 AM
RRMike's Avatar
RRMike
A sterling 10.5 inch rear and a dana 50 front.
Old Jun 10, 2003 | 11:02 AM
X-bus's Avatar
X-bus
Thanks man. I have a wierd soft sounding clunck too. It only does it when I accelerate from a complete stop. I hit the gas and it feels like there is some slack in the drive line or something. What do you think? Thanks!
Noah
Old Jun 10, 2003 | 11:11 AM
MrRottnDog's Avatar
MrRottnDog
I'd check thr U-Joints first!
Old Jun 10, 2003 | 11:16 AM
X-bus's Avatar
X-bus
10-4 I'll check the u-joints. Do I have to put the truck on jackstands to check them?
Noah
Old Jun 10, 2003 | 03:55 PM
RRMike's Avatar
RRMike
Hey Rottn,
You are an X guy so you may know something I don't but isn't that an 02 or newer X. I know the SD's changed headlights in 02 but not 100% on the x's. Also I'm not too sure on the wheels but I've only noticed them on newer ones like 03's
x-bus,
I posted this in the other place this thread is but are you sure that's an '01. Is that an actual pic of your truck?
Also I would check the slip joint on the rear driveline. Put some grease on them and it'll fix that clunk. It's been documented all over these boards.
Old Jun 10, 2003 | 05:03 PM
MrRottnDog's Avatar
MrRottnDog
rrmike,
Your right about the slip joint.
I also thought they didn't have the good headlights until 2002. I know My 2001 limited did not have them.... but your eyes must be better than mine I can't tell from the picture.
The wheels look to me to be what was on my limited when new... but they were on there for such a short period of time I'm not sure. (JOEBOOST would know I sold them to him!) I'm on my fourth set of wheels and tires now.
1. Stock LT265/74RX16D on stock aluminum wheels
2. 35/12.50R/16 Super Swamper SSR's on 16x10 Centerline Hellcats.
3. 36/14.50R/16 PJ's on 16x10 Weld Stone Crushers
4. 39/18 Mickey's on Weld 16.5x14 Mountain Crushers
Old Jun 10, 2003 | 05:15 PM
X-bus's Avatar
X-bus
Originally posted by rrmike
x-bus,
Yeah, that's a pic of my truck. Does it look newer than a 2001? The headlights? Wheels?
I'll check the slip joint on the rear driveline. Thanks!
Noah
Old Jun 10, 2003 | 05:45 PM
RRMike's Avatar
RRMike
Yes they are 2002 or newer headlights and corner lights.
Old Jun 10, 2003 | 05:48 PM
X-bus's Avatar
X-bus
Interesting. Maybe the previous owner added the headlights. What about the wheels?
Which part do I need to grease? The slip joint on the drive shaft?
Noah
Old Jun 10, 2003 | 05:56 PM
RRMike's Avatar
RRMike
The part that's covered up by that black boot.
Old Jun 10, 2003 | 05:59 PM
RRMike's Avatar
RRMike
Oh yeah, the headlights and corners I'm sure about. The wheels I'm not positive but I've just never noticed them on an older one.
Just pull the driveline down and pull that boot off and slide the splines out and cover them in grease and slide them back in. Then you'll have to reattach the boot. Perhaps with zip ties or hose clamps or whatever. Then bolt the front or rear of the driveshaft (whichever you disconnected) back on.
Clunk gone
Old Jun 10, 2003 | 06:01 PM
RRMike's Avatar
RRMike
Oh also don't take the splines all the way out! Or at least if you do mark them so you can be sure to get it back together lined up right. They are balanced.
Old Jun 10, 2003 | 06:05 PM
X-bus's Avatar
X-bus
Ok, thanks Mike!
Noah
