Sponsored by: Real Truck
Conversion Help/Recomendations
Old Oct 16, 2013 | 03:25 PM
  #31
xmontex4's Avatar
xmontex4
Foudn this site a while back when i was thinking of swapping out the frame on my 95 to make it a RCSB dually Fiberglass Rear Dually Fenders - Lowest Prices! not sure if its much of any help but at least there's an option for fenders.
Old Oct 16, 2013 | 06:03 PM
  #32
Sarge261's Avatar
Sarge261
It does help, Im just worried about fitment on the A/M stuff. If that's the route I have to go I may just get them from Arrow Craft as well.
Sarge
Old Oct 16, 2013 | 06:14 PM
  #33
dlibson's Avatar
dlibson
The bed sides are pretty similar. So they should work.
Watch CL for fenders or a whole bed. You can resell your bed then. The last one I did, I found a set of fenders for $500. I think we've discussed that before. For $2000 you can find a new take off bed with fenders, and sell yours for $1200 after...
Old Oct 16, 2013 | 06:24 PM
  #34
Sarge261's Avatar
Sarge261
Yeah the problem is finding short bed dually take off...they are like non existent lol.
Are you saying that the A/M fenders are close, if so what company do you have experience with?
Sarge
Old Oct 16, 2013 | 06:49 PM
  #35
dlibson's Avatar
dlibson
I've used a few brands. The Arrow Craft ones are good too.
You could just find the fenders and make something for the fuel filler too. I've seen it done before.
I've used these before too and they were good and reasonable. Dually Fenders for Ford Dually Trucks, 1980-2013 Model Years
Old Oct 16, 2013 | 06:58 PM
  #36
texastech_diesel's Avatar
texastech_diesel
Token Redneck
So this might be a no-ga bat-***** crazy idea..... but here goes anyways. If you're going to a convert it to a dually, might as well make her legs longer to go with the new hips.
Get a transfer tank, then direct plumb it into the fill neck with a valve solenoid in the line. Hide the old fill neck with a standard dually fender and fill the truck through the t-tank. Or if you want to hide the tank under a soft bed cover, get a small one that's 30ish gallons with a manual valve; you fill the t-tank, open the valve, and can't overflow the stock tank.
Or get a full Transferflow setup that has the fancy little box and the fuel pump in it, and always fill through the t-tank and transfer to the main tank. They make a 37gallon model that should fit under a cover and avoid the 5th wheel hitch.
It's fun to make-believe when it's not my money
....of move the fuel fill to the inside of the new fender. Seen that before too for rear aux tanks.
Edit:
http://www.wallisduallyfenders.com/f...-fill-opening/
This?
Old Oct 16, 2013 | 07:01 PM
  #37
dlibson's Avatar
dlibson
I can spend other peoples money really easily Bryan! LOL
Old Oct 17, 2013 | 07:56 AM
  #38
Sarge261's Avatar
Sarge261
Ha I can too. I did have a Transflow tank in the truck a few years ago, but I removed it cause I wasn't towing long distances. Well that all changed again when the wife wanted a new 5er, so now we are towing again. I do have a Titan tank in the stock location so with 44 gallons on board I do ok.
I can work around the fuel filler issue that's not a big deal, my worry is with the quality of the A/M fenders all together, the reviews on these things are mixed.
I was thinking that the 11-up dually fenders wouldn't look too bad on our style trucks because they aren't as big, and they don't look like they would make me have to monkey with the fuel door at all, which means less bodywork, which I have to pay for.
So D, did you use just the dually fenders or the conversion kit, and if you used the kit how well was it constructed? That is my other worry, without being able to put my hands on 1 or talk to someone that actually used it I'm a little nervous to pop on a 1600.00 what if?
And as always my issue is will the adapters fail and I cause more harm to my truck or god forbid someone else on the road.
I still have much to think about.
Sarge
Old Oct 17, 2013 | 08:39 AM
  #39
xmontex4's Avatar
xmontex4
I saw an 04 drive by with a 2011 dually bed. Long bed but it didnt look that bad I kinda like the new fenders. they are different so they stand out and I doubt you would need to move the filler hole.
Old Oct 17, 2013 | 10:32 AM
  #40
Sarge261's Avatar
Sarge261
That's what I was thinking as well Monte...no I need to try and find a set of OEM dually fenders to see for myself.
I cant even find part numbers for them.
Sarge
Old Oct 17, 2013 | 10:48 AM
  #41
xmontex4's Avatar
xmontex4
Here is a link to the Fender diagram with all the prices of the parts
2011 FORD F-450 Super Duty Parts - AutoNation Ford White Bear Lake Parts (previously Tousley Ford Parts)
No part numbers though you could probably message them and as however. They might ask for a vin so go onto ebay find a dually give them the vin then they will send you the part numbers, i do it all the time when looking for parts out of other trucks that don't match mine. They even told me to go on ebay and find vin's to pull part numbers from lol.
Old Oct 17, 2013 | 01:12 PM
  #42
dlibson's Avatar
dlibson
Sarge
I've done both. I used OE, and the ones I linked you too for $350 ea. They fit really nice actually and it is setup with the filler door.
I have seen a 05 body style driving down the road with the 11 style fenders too...
Old Oct 17, 2013 | 02:36 PM
  #43
Sarge261's Avatar
Sarge261
Snap a picture of that thing if you see it again...
Old Oct 17, 2013 | 10:29 PM
  #44
dlibson's Avatar
dlibson
I'll keep my eyes out!
Old Oct 30, 2013 | 10:44 AM
  #45
dlibson's Avatar
dlibson
2006 FORD DUALLY BOX
