Constant charge
Old Jun 18, 2013 | 04:59 PM
Vinford's Avatar
Vinford
Constant charge
1999 F-350 7.3 dually.
I have no 12v power coming out of my trailer plug to charge travel trailer battery?
Is there a fuse somewhere or where does that power come from?
Old Jun 18, 2013 | 06:43 PM
RV_Tech's Avatar
RV_Tech
Do you have your ignition turned on?
Steve
Old Jun 18, 2013 | 07:13 PM
Vinford's Avatar
Vinford
Steve
yup had the ignition on I drove for 200 miles and nothing charged up , thats when I started checking further.
Old Jun 18, 2013 | 07:23 PM
RV_Tech's Avatar
RV_Tech
Relay or fuse then would be the obvious selections, although you may simply have a corroded seven pin making poor contact, usually on the back or underside of the rear of the truck. The seven pin receptacle is an ongoing problem child. Check with a volt meter on the charge pin, but give the fuses and relay a once over. You did your checking after it didn't charge with the ignition on right? A relay will open and kill the charge output when the ignition is off.
Has this system been working in the past?
Steve
Old Jun 18, 2013 | 07:53 PM
TexasRebel's Avatar
TexasRebel
is there a good battery to charge?
Old Jun 18, 2013 | 08:30 PM
Vinford's Avatar
Vinford
Steve
Where and which relay?
I imagine the syestem worked im the second owner and the other owner pulled a 5th wheel trailer all the time.
Everything else works./
Old Jul 25, 2013 | 08:22 PM
iwritesql's Avatar
iwritesql
Did you have any luck finding a fuse or relay? My 2005 Super Duty has the same issue--no power on pin 4 when the key is on the "on" position and running.
Old Jul 25, 2013 | 08:54 PM
senix's Avatar
senix
check the relays under the hood at the power dist. box. Should be a legend there or in your owners manual for your year.
Old Jul 25, 2013 | 10:06 PM
SpringerPop's Avatar
SpringerPop
This is for Ken (Vinford).
This should be, in fact, quite simple.
See the attachment below for some assistance to this problem:
There is a small "doghouse" that sits beside the under-hood fuse box. Make sure both relays are in there, and Fuse 24 in the under-dash fuse box, and Fuse 18 in the under-hood box.
Pop
File Type: pdf
Old Jul 25, 2013 | 10:20 PM
SpringerPop
Here's that relay box:
Pop
Old Jul 25, 2013 | 10:24 PM
iwritesql's Avatar
iwritesql
Thanks for the reply guys. I was able to determine that it was fuse "107" under the dash. This is a light blue 20A square fuse in the top row second position from the left. Thanks again.
Old Jul 28, 2013 | 01:35 PM
Vinford's Avatar
Vinford
Underhood fuse gone thank you.
Eric Harang
All Things Towing
Oct 13, 2015 07:32 AM
jwhopson
15
Jul 7, 2011 12:07 AM
jimwilsonmasonry
Oct 19, 2009 07:59 PM
putergeek
20
Jun 28, 2009 11:16 AM
Foamy
Aug 3, 2008 08:48 PM
